Old 11-11-2013, 12:22 AM   #1
Tdubbyount
Tdubbyount's Avatar
Dual alternator setups?
I've got a lot of amp sucking goodies on my square and I'm looking for a way to power them! I have a brand new alternator that's been sitting on a bench for a couple years now and an idea popped into my head today. Anyone seen any clever dual alternator setups? I've already got a power master 1 wire. The other ones a three wire, so I'm not worried about wiring it up, just mounting. It's a non serpentine setup, no a/c long water pump, and currently my alternator is mounted the high mount passenger side style. And ideas, pics or advice will be greatly appreciated. Not looking to spend a bunch of money so those fancy billet kits are out of the question. Thanks in advance!
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one.
1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose.
Tdubbyount is offline   Reply With Quote
Old 11-11-2013, 06:07 AM   #2
donut
donut's Avatar
Re: Dual alternator setups?
Haven't seen any dual alt setups, though I do remember seeing a swap to use a later model, high output alt.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-11-2013, 06:48 AM   #3
dieseldawg142
dieseldawg142's Avatar
^^x2, never seen dual alts either. i think it would be easier to go dual battery's with a big honking alternator.
dieseldawg142 is offline   Reply With Quote
Old 11-11-2013, 08:06 AM   #4
Dead Parrot
You might be able to put a 2nd one where the AC compressor would normally sit. If you currently have a 2 belt setup, you would need to get a 3 belt pulley set from a local pull a part place. The AC belt normally catches the PS pump as well.
Dead Parrot is offline   Reply With Quote
Old 11-11-2013, 11:29 AM   #5
Skunksmash
Skunksmash's Avatar
You'd probably be a lot better off just going with a single alternator that puts out more power and is more efficient. Take a look at Polar Power. And one of those $230 XS power batteries.
Skunksmash is offline   Reply With Quote
Old 11-11-2013, 12:33 PM   #6
aotte1
The 6.2 diesel in certain trucks have dual alternators, 454 ambulance applications also had dual alternators. Checks/ auto parts store and they can tell you what years apply.
Les
aotte1 is offline   Reply With Quote
Old 11-11-2013, 12:42 PM   #7
Keith Seymore
Keith Seymore's Avatar
Les
Yep - came here to say this as well.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-11-2013, 12:46 PM   #8
aotte1
Agree with above suggestions that easiest way would be to use single high output alternator. Have run duals, k30 and they were a problem even when factory installed. Making a setup from other chevy applications is possible, however, lots of work, e.g. Getting the right pulleys and making it all work will take some time.
Aftermarket high outputs are pretty good, only look different from original.
Les
Old 11-11-2013, 01:59 PM   #9
gmachinz
If you are running a GM style serpentine kit, I designed a bracket kit to use an aux. Alt. where the smog pump originally mounted.....thus giving you 220A total if you use the GM counter replacement alts. However, I would suggest a dual battery setup since you could easily support such a system then.
gmachinz is offline   Reply With Quote
Old 11-11-2013, 02:27 PM   #10
83GMCK2500
Tdubby...remind me what motor you have in your truck. I can look at different serpentine setups and see if one might be dual alt.
In the meantime, here is an alternator upgrade thread on here.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-11-2013, 06:26 PM   #11
Tdubbyount
Tdubbyount's Avatar
It's a 350, I've been looking around and I've found a bunch of serpentine kits that can mount dual alts, but they're freakin expensive!
Old 11-11-2013, 06:46 PM   #12
gmachinz
It doesn't have to be expensive....I use factory 305, 350 or even 4.3 brackets and they will all accept my CNC water jet cut aluminum brackets so long as it has a smog pump provision.
Old 11-11-2013, 08:44 PM   #13
xole
xole's Avatar
Give Alan Grove Components a call. All they do is accessory brackets.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 11-11-2013, 08:49 PM   #14
Tdubbyount
Tdubbyount's Avatar
I'll look into it. Thanks for the feedback guys
Old 11-11-2013, 10:15 PM   #15
willett
Another Day, Another Dollar
willett's Avatar
How much current do you need?
Power master makes a 160 amper I believe. Your shedding valuable hp's by having an extra alt
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
