Old 10-29-2012, 12:03 AM   #26
big10ratrod77
big10ratrod77's Avatar
Re: 79 custom deluxe "blue goose"
well ive been saving up and buyin parts and stock pileing them for the old blue goose the engine is still not assembled the block has been primed and the head has been painted chevy blue, when we slow down this winter we will get the engine assembled.
well i have worked som more on my bed pan cleaning and priming also built a nice bed stand out of old pallets from work
also ordered a bunch of my weather striping from brothers trucks while they were on sale i also ordered doors, a rear sway bar 1", door handles, tail lights alot of the small stuff i will need after paint
heres how my truck sits now i have learned that you should install sway bars before all your exhaust work is done this caused major issues when it comes to fittment
i will post pics of the bracket i made to compensate for the clearance problem soon...
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 11-07-2012, 11:10 PM   #27
big10ratrod77
UPDATE: ive been working steady every night priming and painting parts some times up until 11 or 12 o'clock at nite
got my brake booster primed and painted (needs one more coat)
got my air cleaner cleaned up and repainted but i think i am gonna redo it in gloss black i used med. gloss black and it dosent look quite like i want it to
had to strip and refinish 3 of my wheels the paint cracked and looked horrable
primed my oil pan next im gonna check for leaks in the pan its self i learned my lesson last time i built an engine.
had to build custom drop down brackets for my rear sway bar it was hitting the bottem of the bed and i also couldnt drill the holes in the frame becouse my exhaust was in the way so i countersunk two bolts into a peice of angle iron and welded the heads flush and ground it down smooththe angle iron is for the passsenger side and it allows me to bolt the sway bar to the side of the frame insted of on the bottem of the frame. the drivers side had plenty of room to drill the holes.
this is my offenhauser intake and ceramic pace setter headers i am planning on painting my intake the same color as the engine.
Old 12-05-2012, 10:39 PM   #28
big10ratrod77
so my block had score marks on the surface wear the head mounts to the blcok so it had to go back to the machine shop, hopefully we can get it back soon so i can start building it.
had a pallot of doors and other parts come in tonite
new doors made of real metal they feel like there of quality thickness(thicker than a beer can)
Old 12-05-2012, 11:11 PM   #29
big10ratrod77
i was sitting around tring to figure out how to make my truck bed mobile so i can get it in the shop to work on it and i stumbled across this video and i got to thinking i can build somthing close to that cheap so thats one of my other adventures
Old 12-24-2012, 01:45 AM   #30
jughead12
love this truck and the work your doing, any updates?
jughead12 is offline   Reply With Quote
Old 12-26-2012, 11:19 PM   #31
big10ratrod77
I got a lot done Christmas eve and today I got a lot of time to put my engine together
Here is my cylinder head with Small Block Chevy valves, .040 shaved off the head, and a 3 angle valve grind.
Block with new main bearings
Cleaned up main caps and bolts
Crankshaft installed
Rods and pistons installed
New head gaskit
Me torqueing down the cylinder head
Mostly assembled engine
i hope to have it all togheter by the end of the week, i also plan to go to a junk yard out in pittsboro friday to get some parts for my 79 and my 77
Old 12-27-2012, 12:12 PM   #32
Wrecked1982
Wrecked1982's Avatar
what brands are those door? i need a set and junkward have to much snow to go walk
Wrecked1982 is offline   Reply With Quote
Old 12-29-2012, 07:29 PM   #33
big10ratrod77
the doors are from brothers trucks they feel like they are quality doors and the metal seems to be realy thick i think they should work fine
Old 12-30-2012, 07:40 AM   #34
moneyeater
moneyeater's Avatar
Cool build! Like the work!
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 02-01-2013, 12:14 AM   #35
rollin thunder
rollin thunder's Avatar
Sweet build can`t wait to see the new straight six buttoned up and love to hear it running soon
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 04-04-2013, 09:43 PM   #36
big10ratrod77
well I finally got my engine fully assembled we had an issue with the exhaust rocker arm washer on #6 (the half moon piece) it was completely worn out so we had to get a new arm and washer, now we are trying to mock up all our bracketry, we are currently looking a 292 power steering bracket from what I have read that will bolt up to my nonintegral head, but we may have to do further modifications to work with our headers I am not for sure yet. Everything bolts up different from the 67 block to the 79 block and it makes it really interesting when you are ordering parts should it be for a 67? or a 79? the shows on tv like gears and trucks never show you how much research and time it realy takes to do all the details of a project
But here is a pick of my 250 all painted up
My next project is to rebuild the front suspension, hopefully I will order the kit from PST this weekend, I took my wheels to a company in Burlington who does sand blasting and powder coating 70 bucks a wheel, i will be going to pick those up next Wednesday before class that night, I ended up buying 4 new Goodyear wrangler RT-S tires. I am almost done with my bed dolly and as soon as i can i will have my bed in the shop torn down, sanded and primed.
Old 04-04-2013, 10:33 PM   #37
owner 84
owner 84's Avatar
That's awesome. I want to buy set of front doors. Do you highly recommend brothers truck or LMC? By the way, how much would a door weight?
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 04-06-2013, 08:16 AM   #38
big10ratrod77
i think the brothers doors are nice doors they are heavy and everything seems to line up good, in the brouthers catilog they claim they sell only the highist quality chevy truck parts and everything i ha ve bought from them i have been completly satisfied about, brothers is having there spring sale so you might want to check and see and see if the doors are on sale. good luck owner84
Old 04-06-2013, 10:32 PM   #39
big10ratrod77
I started modifying the intake for my 250 I was afraid that the transition from the q-jet tp the adapter to the intake would cause a lot of turbulence so i am cutting out the center and grinding down everything for a nice smooth transition.
And I finished welding up the uprights on my bed stand now I and going to have to find some plates to attach the dollies with, and build an adjustable middle
Old 04-07-2013, 11:35 PM   #40
rollin thunder
looking good! can`t wait for a vid of that engine man.
Old 06-26-2013, 11:58 PM   #41
Dusty4x4
Dusty4x4's Avatar
Looking good man and same here on the vid...
1980 1/2 ton shortbed project
1978 grand prix project
Never stop trying...
Dusty4x4 is offline   Reply With Quote
Old 08-03-2013, 08:05 PM   #42
big10ratrod77
a couple weeks ago I finished up on my spring landscaping job and I have been working on my 79 on Saturdays and I have been getting a lot done i have been really short on cash after buying an 01 s10 to be my daily driver and some tools from a man who retired that I worked with, but the progress continues on...
removed front clip to replace the engine and rebuild the front suspention
i also presure washed the engine bay
i laid out the parts in the bed and they are all labled (the smaller parts are boxed and bagged in the cab)
repaired the grill with this super strong appoxy i had
the last spot i have to repair i have a spare grill and i will make a patch to go here then the grill will get a warm sudsy bath a good scuffing and a fresh coat of paint
started claening and painting brackets and my hood hinges
i have been using eletrolisis to remove the rust out of the hard to reach places and it works realy well
my pst front end rebuild kit all i lack is the idler arm and pitman arm
and here is my 01 s-10 with a 4.3 and a five speed way to fast for me lol
Old 08-06-2013, 08:00 PM   #43
Dusty4x4
Dusty4x4's Avatar
Looking good man...
Old 08-06-2013, 08:21 PM   #44
rusty76
rusty76's Avatar
Let us know how the PST kit works out for you. I'm curious to see.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-11-2013, 09:28 PM   #45
big10ratrod77
i will man i used the kit on my 73 duster and it made a huge differance in how the car drove so i am hoping to see the same here
Old 08-12-2013, 07:55 PM   #46
rusty76
rusty76's Avatar
Awesome.
My build thread
Crossmembers CC
Old 08-25-2013, 10:21 AM   #47
Jwood70
Sweet build so far man. I have the same plan for my 79s 250.
How do you like the intake and headers?
2014 single cabF150- Daily. 35s, camper shell and lifted.
1979 Custom Deluxe- project
Jwood70 is offline   Reply With Quote
Old 08-25-2013, 07:26 PM   #48
cleansquare
Subd
cleansquare is offline   Reply With Quote
Old 11-12-2013, 01:13 AM   #49
NONHOG
NONHOG's Avatar
Interested in more "six" posts!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
