Old 10-13-2013, 10:02 PM   #1
Longhorn 70
Longhorn 70's Avatar
Is my heater core going to survive?
The heater core has been dry for years. I recently hoked the houses up to pressure test it with the heater/AC box removed. I see no signs of leakage or do I smell coolant.
Am I going to have to do the job twice?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 10-13-2013, 10:15 PM   #2
swamp rat
swamp rat's Avatar
Re: Is my heater core going to survive?
The heater core is nothing more than a small radiator so unless it leaks and does not hold pressure it should be fine unless there is another problem we cant see.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-13-2013, 10:59 PM   #3
Longhorn 70
It is an older Stant core that I installed in 1993 or so. The newer ones I see today look of lesser quality. I guess if I don't replace it and it starts to leak, it will be a gain of experience and wisdom. I'll go for it.
Old 10-14-2013, 07:27 AM   #4
rsavage
rsavage's Avatar
I have made a decision to install a new heater core everytime I restore a vehicle, especially one of these trucks with AC as they are a bear to change out once everything is put back together. I am currently doing my 65 GTO and although the heater core didn't leak when I started taking the car apart to get it ready to go to paint, it will be a year and a half or so since it last had coolant through it when it gets back together. So, for piece of mind, I will change it out before putting the car together again because I just don't want to trust a 48 year old heater core. Obviously your decision - just posting what I would do.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-14-2013, 07:34 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Is the truck now in running condition?
If yes, here is what I would do to be sure. Use the heater hoses and hook the heater core up outside of the heater box. Use a coat hanger or bungee to hang it up. Make sure it is not to high or it will get air trapped in it. Run the truck and let it go through a couple of heat cycles. This will let you know if it is going to leak or not before you trouble with the installation only to find it is bad.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-14-2013, 02:40 PM   #6
Longhorn 70
I do have it installed right now where it should sit. It is also open to the outside air. If I were home I'd send pictures. Immagine the heater core and interior parts in place but the heat/AC box under the hood is out. I am driving the truck but it is cool out. Maybe I'll block the radiator a bit and get the heat up to 200° or so. Drive it for a few more days first.
rsavage thanks for the input. I did consider that too. It seems many of the new parts I have been gettting are just so....cheap feeling. I don't know whether to trust old stuff or new stuff anymore.
Old 10-14-2013, 02:45 PM   #7
cdowns
cdowns's Avatar
the reason alot of heater cores fail is due to the radiaror cap being too high of a pressure/// a lifelong radiator guy advised my of this many many years ago and i usually stick with a 8-10lb cap
Old 10-14-2013, 07:00 PM   #8
Longhorn 70
THANKS for that bit! I'll get a new cap and have it tested.
Old 10-14-2013, 09:14 PM   #9
slow-1
slow-1's Avatar
I just replaced my heater core over the weekend...the first core I got from Advance Auto was aluminum and did not fit, the ends of the core were not the same shape as the original so the bracket didn't fit.
Took it back and the parts girl called another store about 10 miles away and asked them to look up the same part number and they had one that was brass and correct. The guy at that store said he figures it had been on the shelf for 10 years or more.
Moral of the story, find a brass one if you decide to replace it.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 10-15-2013, 08:15 PM   #10
lha1992
lha1992's Avatar
I have never heard of that being the case. I thought these truck all came standard with the 15 or 16lb caps. Gonna look into this cause I just put in a new heater core 2 weeks ago.
lha1992 is offline   Reply With Quote
Old 10-16-2013, 09:27 PM   #11
1972RedNeck
1972RedNeck's Avatar
I always run a cap around 7 lbs. Even if the system will take it, it's easier on it if you stay lower.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-12-2013, 02:09 PM   #12
Keating121
Keating121's Avatar
Here's mine. Is your's looking like this Longhorn?
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
