11-12-2013, 10:40 PM | #1 |
Carpe manana
Educate me: Why is this bracket attached to the AC controller, what trucks had them?
Here's an AC controller I found loose in the back of a Suburban at a salvage yard (together with most/all of the parts for a 72 burb rear AC setup). Why is the bracket in the photo attached to the AC controller? That on my K20 never had this bracket - it's just bolted to the dash like a heater controller. Also, the screws that affix this bracket to the AC controller are coarsely threaded like those for a heater controller but unlike the fine thread screws that attach my K20 AC controller.
What trucks had these and why not skip the bracket all together?? Is it for a Blazer/Jimmy to attached the underdash speaker? How is YOUR AC controller attached?
11-12-2013, 10:54 PM | #2 |
Re: Educate me: Why is this bracket attached to the AC controller, what trucks had th
In picture one, the two open holes on the outside, those are the mounting holes that hold the unit to the dash. It's upside down in the picture. Two good sized screws come in from under the dash and hold it in place.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-12-2013, 11:02 PM | #3 |
Carpe manana
Thanks! I get that part. What I'm wondering is why is this bracket necessary? Other AC controllers I've seen (including that currently on my K20) don't have this bracket at all and are attached directly to the dash. There aren't two styles of AC controllers are there? Were there differing dash holes: one set close together the other further apart?
11-12-2013, 11:05 PM | #4 |
OK, can't answer to that, my C10 has the bracket.
11-13-2013, 12:28 AM | #5 |
Carpe manana
Huh - am I totally mistaken and ALL AC trucks had this bracket? My K20 isn't here yet for me to check but IIRC it bolted onto the dash just like the heater controller in my K10 - no bracket needed.
11-13-2013, 07:37 AM | #6 |
Old member
I have never seen a AC controller that didn't have that bracket.
If yours doesn't have it please post some pictures of it and how U have it mounted please.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-13-2013, 08:28 AM | #7 |
I pulled my broken one out of a box for my blazer and it's exactly like your pics. Even with the black screws. Other threads are coarse. I hope you get your trucks soon man.
11-13-2013, 08:54 AM | #8 |
Florida Edition
They all came with that bracket.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-13-2013, 09:10 AM | #9 |
FYI this same control was used in 65-66 Impalas and I think they added bracket to fit trucks. Jmo.
11-13-2013, 11:49 AM | #10 |
Carpe manana
Thanks guys - I must be mistaken and will check the K20 when it arrives - hopefully on Sunday. Pete
11-13-2013, 12:17 PM | #11 |
uncle is correct, same controller as Impala [GM was resourceful back then]. All A/C trucks had the adapter.
