Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-07-2013, 05:30 AM   #2176
skorpioskorpio
Re: PO has me PO'd
Tablet?
skorpioskorpio is offline   Reply With Quote
Old 11-07-2013, 10:45 AM   #2177
mtully79
mtully79's Avatar
Re: PO has me PO'd
I use a table.
mtully79 is offline   Reply With Quote
Old 11-07-2013, 01:16 PM   #2178
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by swamp rat View Post
Humm, the only tablet i know how to use requires a sharpened pencil..
Originally Posted by skorpioskorpio View Post
Tablet?
Originally Posted by mtully79 View Post
I use a table.
You guys crack me up, what a bunch of imaginative writers we have around here.....
Im sure im not using this device to its fullest capabilities, but i get by
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-07-2013, 09:23 PM   #2179
swamp rat
swamp rat's Avatar
Re: PO has me PO'd
Lol!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-08-2013, 02:09 PM   #2180
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got a couple minutes to go back and work on my fuel lines while i wait for some tools and parts to come in....SS axle brake lines, and extended braided T hose. Also, just ordered from Jegs is my MSD noise filter ( 8830 )....EMI be damned
In the first pic, they seem to be rubbing the two rivets, may have to build a standoff, as i dont know the long term effect of this condition.....or grind a notch in the rivet head
20131108_125257 by jarosaj, on Flickr
20131108_125153 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-10-2013, 11:51 AM   #2181
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got a couple hours to continue on my fuel lines. This copper/nickle flares very easily, unless you put your barrel nut on backwards ( dah), you wont have to flare it twice. I used a single flare, as i havnt heard any need for a double flare on fuel injection. Also, i flared to 45 degrees, since i read -6 and -8 are unversal sizes and dont require a 37 degree flare. Dont ask me why.....but,if i have any leaks ill know why
The last double clamp has to be moved closer to the top of the frame, some clearance problems at shock mount on the lower fuel line
Now, its on to the flexible hose from russel, have to build a transition clamp from vertical to horizonal
20131110_102108 by jarosaj, on Flickr
20131110_102316 by jarosaj, on Flickrj
20131110_103032 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-12-2013, 02:00 PM   #2182
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK, this morning i finally got the gas tank mounted up in the factory location....ended up making 5/16" shims to put on top of the oem location spacers ( keeps tank from shifting side to side ). Also, took off a black electrical box on the fuel pump, dont know what it was for, but im guessing some sort of vent.
Sheesh, am i glad that problem is solved. Tons of trial and error went into that project, thought i had failed many times, but persistance paid off. If that project didnt work, it would have put my whole fuel injection system swap at risk, plus the 400.00 investment for tank and pump
If i had only known the the placement of the pump was so critical, i wouldve, couldve moved the pump forward a inch for clearance. Oh well, everyone has 20/20 hindsight
Now, with that problem solved, i can move onto my fuel lines
20131112_124701 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-12-2013, 03:07 PM   #2183
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: PO has me PO'd
Looking good. Just keep plugging away and you'll be ready to fire it up soon.
hgs_notes is offline   Reply With Quote
Old 11-12-2013, 03:40 PM   #2184
Dale99
Re: PO has me PO'd
Your fuel lines are going to look 100x better then mine.
Dale99 is offline   Reply With Quote
Old 11-12-2013, 06:02 PM   #2185
mtully79
mtully79's Avatar
Re: PO has me PO'd
Can't argue progress...looking good. What did you decide to do with the fuel lines contacting the rivets?
Old 11-13-2013, 01:42 PM   #2186
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks guys for checking in....
Ill not lie to you, and say that i was not very concerned about this system not working, im really a stock kinda guy. This is my first attempt at modification, and i would look like a total idiot in front of my peers and mentors if i didnt pull it off. Abit nerve racking having 60,00 gearheads looking over your shoulder at all times. Plus the fact that i would have thrown away $4,000.00, which would have made the CFO unhappy....gotta love her for keeping me in check lol
Ive decided to make the 5/16" shim and anti-shift device (for lack of a better term) as one, ordered the 3/4" stock from McMaster Carr. Gotta luv having a well stocked hardware store at your disposal...
Tully, i think it would be better to build a standoff, rather then mess with the structual integrity of the rivet. These 4 rivets support the front of the spring hanger, and i wouldnt want to be driving down the road and have that system fail. Could get ugly real quick...
Dale, i went with 'form over function', nothing wrong with 'function over form' Glad youre making progress on that wiring harness. Youre a braver man then me, tackling that harness. No more carbs!
HGS, your truck looks cool blasting thru the snow, plus that one pic show cases all the work you put into your hood, great job. Enjoy driving it on those starry nights. Wait, wasnt that a song...Starry, Starry nights, give it a minute, and the melody will come
SAFETY FIRST
AS usual, off topic
Jim
Old 11-14-2013, 02:20 PM   #2187
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
3/4" stock came in today, so i thought id play around with the radii required to fit up to the tank. Drew a couple referance lines (.200 ) down the top and sides, and used the old lead file to shape it. Just use a file brush to keep the teeth clean, and there will not be any gouging
20131114_131103 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-14-2013, 08:00 PM   #2188
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: PO has me PO'd
Old 11-14-2013, 09:42 PM   #2189
swamp rat
swamp rat's Avatar
Re: PO has me PO'd
I love that antique Vixen file mount, wish i had one too.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-15-2013, 12:10 AM   #2190
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks HGS! now that tune is stuck in my head
Dang swamprat, never new that tool had a name, one of my favorite tools for soft metals
SAFETY FIRST
AS usual, off topic
Jim
Old 11-15-2013, 01:47 AM   #2191
swamp rat
swamp rat's Avatar
Re: PO has me PO'd
Vixen files cant be beat for large block aluminum removal!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-05-2013, 02:18 PM   #2192
mtully79
mtully79's Avatar
Re: PO has me PO'd
How's the progress? Hope you had a good turkey day!
Old 12-06-2013, 12:15 PM   #2193
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Not much, tis the season,and my mind is on the wifies present(dangly earrings $)
But, i did get the tank fitted to the frame,but 5/16" drop really messes with the filler neck
Got the ss brake lines from in line tube, and the pass. side is 3/4" too long. Also, put new SS washer head bolts in my wheel cylinders (totally stainless) has the correct bolt head size, i went oversize....
First time i used the master series coating, really nice stuff.
This filler neck is giving me fits, may have to relocate, or ideas?
20131119_125259 by jarosaj, on Flickr
20131204_111341 by jarosaj, on Flickr
20131206_103805 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 12-06-2013, 05:23 PM   #2194
mtully79
mtully79's Avatar
Re: PO has me PO'd
I was able to use my old filler neck and had it welded on the new tank with minimal install issues. I used marine hardwall fuel hose to complete the job.
http://www.overtons.com/modperl/prod...ID=1006&r=view
Old 12-06-2013, 09:52 PM   #2195
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Found 1 3/8", filler neck supply, sells it by the inch, but ive cut my oem filler neck within an inch of its life. Sooooo, i may have to start over, after i source a new neck on the classifieds....stay tuned for this saga, fustrated to say the least
SAFETY FIRST
AS usual, off topic
Jim
Old 12-08-2013, 06:48 AM   #2196
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks tully for taking the time for your response, but at this time, i think ill just move on to the next part of the build, ie fuel lines. Put the filler neck behind me, to save my sanity.
Ive got plenty to do in other areas, and just tired of focusing my attention on my tank
SAFETY FIRST
AS usual, off topic
Jim
Old 12-08-2013, 10:45 AM   #2197
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: PO has me PO'd
I might have a filler neck in my parts stash. I can dig around and let you know if you still need one.
Old 12-08-2013, 11:05 AM   #2198
mtully79
mtully79's Avatar
Re: PO has me PO'd
I hear ya on the tank, no sense in getting too frustrated. The truck is coming out awesome, I've been using this thread as a reference so thanks for all the help!
Old 12-10-2013, 11:36 AM   #2199
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks HGS for your very generous offer, the one i need comes off the tank, ill let you you know if it gets to that....really enjoyed watching you play in the snow, i guess faux snow is out of the question on my truck, lol.....dont wanna lose my man card
Tully, glad to hear my thread is being used as intended, lots of pics. for referance
Three major problems that have yet to be worked out
1) twin lever lokar emergancy brake - custom cables $
2) twin stick np 205 - turp is helping
3) fuel neck filler tank
SAFETY FIRST
AS usual, off topic
Jim
Old 12-10-2013, 02:21 PM   #2200
notsolo
notsolo's Avatar
Re: PO has me PO'd
Hey Jim ... I am not going to use the the filler neck that I bought from Thealien Let me know if you need it.... Edward
notsolo is offline   Reply With Quote
