Old 11-14-2013, 06:03 PM   #1
steelhorse
steelhorse's Avatar
Control Arm opinion
I have a set of 71 and a set of 86 upper and lower control arms for my truck. The 71s came with the short frame I bought and the 86s from a parts truck. I am trying to decide which ones to use. Either will get rebuilt before installation. I was thinking the 86s for better ride and newer technology?
steelhorse is offline   Reply With Quote
Old 11-14-2013, 06:55 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Control Arm opinion
The 86 arms will theoretically ride a bit better. They will definitely be cheaper to rebuild though, that's not up for discussion.
Just be sure and use ball joints that match whatever spindles you're gonna use.
Tx Firefighter is offline   Reply With Quote
Old 11-15-2013, 01:15 AM   #3
bbcmudtruck
My truck has a newer model cross member with the 73+ 1 1/4" disc brakes. I just got done rebuilding them and the total was somewhere around $250. I used MOOG parts for everything, including bumpstops, lower and upper arm bushings, new brake pads and new ball joints. I think as long as you keep everything the same, you will be fine. TXFirefighter helped me out a ton when I needed to figure out what front end I had. He also helped me pick out the parts I needed to lower it and replace everything. Shoutout to TXFF!
bbcmudtruck is offline   Reply With Quote
Old 11-15-2013, 09:22 AM   #4
steelhorse
steelhorse's Avatar
Thanks guys. I was already leaning that way just want some other opinions.
