Old 03-06-2009, 04:30 PM   #1
JJanzen
JJanzen's Avatar
Thru the Firewall
I am pulling apart a 1972 A/C cab and was curious about the speedometer cable, the parking brake cable and the wiring bundle right next to the parking brake cable as shown in the picture. Do I need to disassemble those cables or just pull them through the firewall with the rubber grommet? Any help would be appreciated! Also, are all the firewall rubber grommets available new and which vendor would you recommend. Thanks.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 03-06-2009, 04:50 PM   #2
72blue
72blue's Avatar
Re: Thru the Firewall
Just use a screwdriver to gently break the seal arount the grommet and the push the grommet thru the firewall. The ends of the cables (elect., park, and spedo) will have more than enough room, as far as I could remember anyway. I like GMC Pauls. I have not bought all the replacement grommets yet, but I'm sure they will have them.
James
James
72blue is offline   Reply With Quote
Old 11-14-2013, 07:48 PM   #3
elf w/capital T
Did you ever find factory replacement grommets? Where at?
elf w/capital T is offline   Reply With Quote
Old 11-14-2013, 08:38 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Someone on here may be able to answer your question but JJanzen himself hasn't been on the board since 8/8/13.
Just a heads up.
LockDoc
Leon
Old 11-14-2013, 08:43 PM   #5
elf w/capital T
Haha! Yikes, I guess when bringing the posts back from the dead I should look at that huh? Lol thanks lockDoc!
Old 11-15-2013, 05:58 PM   #6
john
member #16
john's Avatar
Wes at classic heartbeat has had them reproduced.
http://www.classicheartbeat.com/rubb...atherstrip.htm
john is offline   Reply With Quote
Old 11-15-2013, 08:20 PM   #7
TacBlade
I just bought every one of them form LMC. They seem to be good rubber?
TacBlade is offline   Reply With Quote
