Where to find Pitman arms?
I'm rebuilding my front end and the only thing I'm missing out on is a new Pitman arm. Mine's sloppy and needing retirement, but boy, a new one for my build is almost impossible to find!
72 K20, with a 77' K20 Dana 44 front end, however my research shows no difference for the pitman arm between the years 67-87. Any help locating NOS or aftermarket arm would be very much appreciated! |
Re: Where to find Pitman arms?
I haven't bought one since GM still had them and never had a problem finding a good used ones,so I didn't realize these weren't commonly available. Of all the GM 4wds I've had I've only had one worn at the sector shaft end. I guess you could post a WTB in the parts board if no one else knows a source. I just checked NAPA and they don't list it.
Did you try NAPA or CarQuest? I would think this is still available, it was a few years ago.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
I am a Referee of life.
I got a new one from Advance about 3 years agoo.It was for a c10 so there may be fewer 4X4 ones available.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
i just googeled "pitman arm 1972 K20"(30 seconds to do)
got a result with a bit over 100,000 hits???where exactly have u been lookin???
#6 | |
I'm usually great about finding stuff google/ebay/local but this time the 4x4 arm just sees almost impossible as posting is my last resort in these cases |
Google is a keyword search that will find any and all words you type in any order, not necessarily together. In order to aid the search you'd have to use quotations. That let's you search the phrase specifically. I'd say check the parts boards here and put up a WTB.
I rebuilt my front end and bought an Ac Delco pitman arm. I can get part number if you need it. Sorry looks like you need a 4 wheel drive one
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
Wow spendy!
![]() Join Date: Mar 2003
Maybe I should have held on to the 1/2 dozen I just scrapped out last week
Rockauto has them for about 30 bucks...
Chris |
![]() Join Date: Oct 2013
I checked the availability on them at work this afternoon and it their discontinued at NAPA too.
#15 | |
It's not exactly a "wear" item, why would you need to replace it?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#16 |
#17 |
Yeah,like I said before,I've had only one needing replacement out of the several GM 4wds I've had. This is on the '72 GMC in my sig. I rebuilt the front end and the truck would still "dart". Although the steering box had no slop,I decided to replace it. Burt4x4 was generous enough to give me the (low mile rebuilt) one he pulled from his Blazer when he went to crossover steering. Before I put that in I checked one more time with someone at the wheel while I watched and saw the pitman arm to sector shaft play. I just put a used one I had on and called it good. 99%+ of used ones will be good and that's my point,you'll be fine with a used one. As Longhair said,It's not a (common) wear item. I'm sure this is why you're not finding them offered by replacement part companies. I would like to know how Classic can have these and no one else. Could those be N.O.S? Or,did they have some made and trying to keep it exclusive,which would explain why they need so much for them. If they're not,than what would a N.O.S. be worth???
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-07-2013 at 08:19 AM. |
#18 |
not to hijack the thread, but I found a similar problem trying to locate a "Drag Link or Center Link for a 71' swb, it's not considered a wear part and thus, been discontinued......just FYI.....
Ben |
#19 | |
![]() Quote:
Sam |
#20 | |
425hp409
![]() Join Date: Oct 2008
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
