Old 11-17-2013, 11:30 AM   #1
kalbert
Re: I think the shop is took my truck into messed it up
There isn't really a wrong way, it will only go on one way. It mounts to the frame on one end and the drag link in the other end. What's leading you to think yours is wrong?
kalbert is offline   Reply With Quote
Old 12-01-2013, 09:01 PM   #2
LONGHAIR
What? Frame and drag link?
No, it goes between the axle housing in the tie-rod. An '85 should have a bracket welded to the housing near the center, close to where the tube goes into the casting. The other end is a tapered hole in the tie-rod itself, closer to the driver's side.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
