Old 11-17-2013, 03:03 PM   #1
7d1truckguy
7d1truckguy's Avatar
Rear window install
Hello , I just scored a near perfect rear window for my big back window truck $10.00 at a swapmeet , Question, I have an after market rear sliding window in it now, But it has the factory rubber and chrome around the outer edge, My question is do I need to remove the outer rubber and factory chrome to get the new window in, THANKS
7d1truckguy is offline   Reply With Quote
Old 11-17-2013, 03:23 PM   #2
bonnieclyde100
Re: Rear window install
i think so because when install back glass you need to put seal around glass before installing in the cab at least that is how i had to install mine. if you doother way you could break the glass
bonnieclyde100 is offline   Reply With Quote
Old 11-17-2013, 03:53 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Yes you do. it has been noted that the chrome strip in the rubber cab be real difficult to install. I went from slider to flat glass with a new rubber snd chrome strip and took the truck to my local pro-glass shop to have it installed. I have found that sometimes its better to let a pro do certain jobs.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-17-2013, 04:08 PM   #4
'68 Short Step
'68 Short Step's Avatar
I did a rear slider to solid glass install last week. I did the cord in the rubber trick and it was fairly easy. I ordered my new rubber from brothers. You can get standard or deluxe with the chrome for the same price. here is a how to link on the install.
'68 Short Step is offline   Reply With Quote
Old 11-17-2013, 08:27 PM   #5
fp1967
fp1967's Avatar
Yes, you need to remove the gasket, trim and window all at the same time. Using a hook tool like in the picture below helps out a lot. A cotter pin extractor tool will work too, but not as good as these hook tools. Don't use any metal tools against the glass, they are for hooking the rubber over the pinchweld on the cab. In the video, it shows them using plastic sticks to pry the gasket over the pinchweld. This method will work, but not nearly as good as a hook tool. The plastic sticks are generally used for working the window into the gasket, hence no metal touching the edge of the glass. The back windows in these trucks are way easier to remove and install than the windshields are.
fp1967 is offline   Reply With Quote
Old 11-18-2013, 07:35 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
If your not re-using the gasket, just take a sharp utility knife and cut through it on the inside and pop the whole thing out. Then you can easily remove the trim and gasket from the slider frame.
Try installing the glass yourself! It's very easy to do even with trim.
I had mine in within minutes.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 11-18-2013, 11:11 AM   #7
CaliLivn
How to replace back window glass seal with cord - YouTube
GREAT video!! My dad put a slider on our 72 an now I wanna put the factory glass back in an luckily he saved it. Thanks for posting
CaliLivn is offline   Reply With Quote
Old 11-18-2013, 04:18 PM   #8
73737373
Yes, installing a back glass using a piece of clothesline was too easy. A warmer day is better because it will make the gasket more pliable, especially if using an older gasket. And, it never hurts to have a little soapy water solution on hand just in case you run into a little bind.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
