Old 12-04-2003, 08:48 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
gauge cluster plastic
I have a cluster with a tack vaccum and speed worning and the clear plastic has the air pressure on it what is the best way to take it off without scratching or discoloring the plastic. I need to put the vacuum sticker on it. thanks gary
Gary 70 Jimmy is offline   Reply With Quote
Old 12-04-2003, 08:55 PM   #2
Gee_Emm
They make stickers like that? I would see if you could use some rubbing alcohol, test it in a hidden spot first, might melt the plastic.
Gee_Emm is offline   Reply With Quote
Old 12-04-2003, 08:59 PM   #3
bigvinnie
bigvinnie's Avatar
Not sure what's available, but if new air pressure lenses or stickers are not available, you might wanna see about selling or trading someone that lens on the parts board before rubbing it off... just a suggestion.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 12-04-2003, 09:22 PM   #4
Huck
Huck's Avatar
I don't believe anyone sells the "air pressure" labeled lense so you might want to trade or sell. You can by a new tach-vac lense for around $40-45. the air pressure is kind of cool if you run air shocks.
Huck is offline   Reply With Quote
Old 12-04-2003, 09:41 PM   #5
Vince M
Vince M's Avatar
I just did mine and I used a few different products to try each. The best one I found is a 3M product called Finish Restorer. It is a very fine polishing compound and if you rub very hard it will take off the paint on the plastic. It also takes out very fine scatches and overall it polishes everything. Give it a try. Another product I tried was a plastic polish. Not much luck there. I tried mineral spirits but it didn't do anything.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 12-04-2003, 09:52 PM   #6
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
The white paint on those gauges can easily be scraped off with a razor blade. just dont cut to deep. I put a set of durangedesign white gauges on my truck and thats how i did it. Don't use paint thinner or mineral spirits or rubbing alcohol, they will put a ugly haze on the plastic.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 12-04-2003, 10:12 PM   #7
Gary 70 Jimmy
Does someone want to trade
Old 12-04-2003, 10:25 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
lens
I don't have one to trade, but would be interested in buying it. Eric
too much stuff is offline   Reply With Quote
Old 12-13-2003, 08:07 PM   #9
Gary 70 Jimmy
vince m where do you get this 3m called finish restorer so I dont have to drive all around looking for it. thanks gary
