Old 11-18-2013, 11:41 AM   #1
crazeetxn
crazeetxn's Avatar
Where do the dots go for TDC
So I'm putting my 350 back together with some refreshed heads. I have the timing cover off as I painted and cleaned up while it was out.
I obviously need to find TDC before I put my distributor back in...there is a lot of info on here about the magic dots, but nothing (that I saw) that said definative, this is what you want/have to do. Just talk about it's on compression or exhaust.
So, dot on crank and cam gear both point at 12, means TDC for #1. Is that when I want to stab the distributor back in, or do I need the crank dot at 12 and the cam dot at 6? I think I had them pointed at each other last time I did this, but that was a few beers ago
Thanks for any help ya'll have...
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 11-18-2013, 01:15 PM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: Where do the dots go for TDC
Yes both are supposed to be at 12 that's TDC for #1. Reason I know is I just finished putting mine back together yesterday.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-18-2013, 02:42 PM   #3
geezer#99
geezer#99's Avatar
That is correct but you install the timing chain and gears with the cam dot at 6 and the crank dot at 12 for accuracy. Quite easy to be out a couple teeth if you try to eyeball it the other way. It was designed that way.
Then crank it one turn so you're on #1 tdc.
Old 11-18-2013, 03:46 PM   #4
crazeetxn
crazeetxn's Avatar
Cool. Gonna take a straight edge and get the dots closer at 12 each. Hopefully it'll fire enough for me to get a timing on it. I do remember last time I did it, backfired through the carb, adjusted the timing and bit and it ran like it was made to.
Thanks for the help fellas!
1st - '68 long bed
2nd - '81 SWB
Old 11-18-2013, 04:02 PM   #5
geezer#99
geezer#99's Avatar
After you set it at 12 and 12 crank it round to 6 and 12 and see how accurate you are!
Old 11-18-2013, 10:19 PM   #6
LONGHAIR
It's far easier to set it a 6 and 12, then just drop the distributor at the number 6 terminal instead of number 1.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-18-2013, 11:09 PM   #7
crazeetxn
crazeetxn's Avatar
So it'll be pointing at #6 vs #1? Or it'll be on the right stroke and still point at #1?
Sorry if these seem like rookie questions, but I'm just trying to make sure I have this right with it still on the stand
1st - '68 long bed
2nd - '81 SWB
Old 11-19-2013, 12:07 AM   #8
geezer#99
geezer#99's Avatar
When the dots are at 6 on the cam gear and 12 on the crank gear you're on #6 tdc.
You can install the distributor with the rotor pointing at #6 or you can rotate the crank one revolution and install the distributor with the rotor pointing at #1.
Your choice!
Old 11-19-2013, 01:12 AM   #9
Desert1957
Desert1957's Avatar
Cylinder 1 at TDC
Desert1957 is offline   Reply With Quote
Old 11-19-2013, 07:43 AM   #10
Jake Wade
Jake Wade's Avatar
Your choice!
This is correct.
Jake Wade is offline   Reply With Quote
Old 11-19-2013, 07:45 AM   #11
Jake Wade
Jake Wade's Avatar
Originally Posted by Desert1957 View Post
Attachment 1176705
Cylinder 1 at TDC
Correction, this is at #6 TDC
Old 11-19-2013, 09:18 AM   #12
Katrina/10
Katrina/10's Avatar
Could it be #1 at TDC, but exhaust stroke instead of compression?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-19-2013, 10:14 AM   #13
bnoon
Correct. #6 and #1 are both TDC at the same time. The cam timing will determine where you drop the distributor.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-19-2013, 10:40 AM   #14
Desert1957
Desert1957's Avatar
Never seen a thread so all over the place, bring number one to TDC, align the cam and crank gear as I posted above, drop in the distributor with the rotor pointing to one.
What is the problem??????
Desert
PS: the OP got way over is own head over analyzing the process anyway, C'MON MAN....
Old 11-19-2013, 11:18 AM   #15
geezer#99
geezer#99's Avatar
Desert
Problem is you'll be firing 180* off on #6.
Old 11-19-2013, 11:23 AM   #16
Keith Seymore
Keith Seymore's Avatar
Agree.
I think the confusion is coming from simply stating "TDC #1".
There needs to be a distinction between TDC #1 firing vs not firing.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-19-2013, 11:23 AM   #17
king-918
king-918's Avatar
It doesn't matter if both are at 12 o'clock or cam is at six. Remember TDC is at the end of compression and recheck for that after complete assembly to insure that even though things get moved around you will be spot on
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 11-19-2013, 11:28 AM   #18
geezer#99
geezer#99's Avatar
It does matter!
So you can put the distributor in correctly with the rotor pointing at #1 so it starts.
Old 11-19-2013, 12:13 PM   #19
bnoon
The problem with both dots at 12, you can be a tooth off and think you're correct if you're not looking at the engine straight on. This can be a problem if you're timing the engine in the engine bay and not on an engine stand. It's much easier to see that you're tooth to tooth at the 6/12 position, then rotate to the 12/12 position or vice versa to double check. Dropping the dizzy is easy at either position, you just have to know if you need it to point to 6 (at the 6/12 position) or number 1 (the 12/12 position). Mistakes can be made, we're just giving ways to double check, which is good, because we're dealing with a not-so-confident engine builder here.
Old 11-19-2013, 01:24 PM   #20
crazeetxn
crazeetxn's Avatar
Dang it Desert, you weren't supposed to tell anyone
I started just searching threads, and that led to something else, then I found myself creating my own
Good thing is, I still have the intake and timing cover off, so that'll come in handy when I'm putting the rockers back on...
1st - '68 long bed
2nd - '81 SWB
Old 11-19-2013, 01:47 PM   #21
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Desert
Your engine won't start. With cam at 6 and crank at 12, you better drop distributor pointing at number six if you want it to run. Otherwise, turn crank one revolution until both crank and cam dots are at 12, now drop in pointing at number one.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-19-2013, 01:59 PM   #22
faribran
this is an interesting post.. i have been doing this for years.... lets keep this simple....
did the original poster even change or remove the timing gears/chain? looks like one could just get #1 cyl at tdc.. and jabb in the distributor..... should be good to go..
faribran is offline   Reply With Quote
Old 11-19-2013, 02:03 PM   #23
Tx Firefighter
Remember, there are two TDC to account for. One where the ignition should spark, the other with the valve open. You must make sure you're at the right TDC to drop in the distributor. Just having the harmonic balancer mark lined up is making a 50/50 guess that you have it right. You must have the balancer mark lined up AND compression to assure you have it right.
Old 11-19-2013, 02:33 PM   #24
faribran
yes, the valves must be closed, hence compression stroke..
Old 11-19-2013, 02:48 PM   #25
78maliburat
Post #9 pic is correct your motor is timed.you just have to time the dist ...........................forget all that #6 at tdc crap
78maliburat is offline   Reply With Quote
