Old 11-19-2013, 04:36 PM   #1
Burgie70
Burgie70's Avatar
Unhappy Fuel pump question
Hi folks,
Just got back from a 2 week vacation and had a hard time starting my truck. Normally it starts right up. I noticed there wasn't much fuel in the fuel filter so I used starting fluid and cranked it over quite a bit and finally it started. Drove into town and back and it started fine. Is this possibly a sign that the fuel pump is giving up the ghost because it seems to have let the fuel back out of the filter and I'm guessing the fuel in the bowls of the Edelbrock may have evaporated?
Thanks,
Tom
1970 C-10 350, 350 trans, ps,pb
Burgie70 is offline   Reply With Quote
Old 11-19-2013, 04:49 PM   #2
bigmac73
bigmac73's Avatar
Re: Fuel pump question
not for sure , probably best to just drive it a few days and see how it does
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-19-2013, 05:21 PM   #3
Lemield
Lemield's Avatar
Originally Posted by Burgie70 View Post
Hi folks,
Thanks,
Tom
I have an Edelbrock on my CST and on my C20. They both seem to let the fuel evaporate if they sit. I've replaced both fuel pumps but the problem persists. I've just accepted the fact that I need to crank it over for about 5 seconds, pump the heck out of the throttle and repeat two or three times until it starts.
If you find a fix for this behavior, please let me know.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 11-19-2013, 05:41 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If it ran fine after getting it started, it's not the fuel pump. If it takes a while to start after setting for a day it could be the fuel is draining out of the carb.
I agree to run it a couple of days and see if you still have to prime it. I've used to have a plastic filter and it never stayed full of fuel. I got rid of it years ago and now use a metal one that I replace every 6 months.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-19-2013, 06:24 PM   #5
Burgie70
Burgie70's Avatar
Yes it has always run fine but this was the first time I've let it set this long. The plastic fuel filter never fills up even when it's running. Seems like it should have more fuel in it but it still runs fine that way.
Old 11-19-2013, 06:44 PM   #6
cdowns
cdowns's Avatar
gas evaporates and also goes bad at a very qiuick rate especially the winter blends i have seen
within two weeks for my 08 the fuel quality goes lo enough to set off the warning lights
Old 11-19-2013, 06:46 PM   #7
68gmsee
Active Member
68gmsee's Avatar
It's been a while since I had the plastic fuel filter (15 yrs?) but I do recall it never was full of fuel but the truck ran fine. Maybe someone else that has a plastic filter can check theirs.
06 Trailblazer
