11-17-2013, 11:38 PM | #1 |
14 bolt conundrum
So.....I have the opportunity to get either a 3/4 ton ff with gov-lock or a 1-ton single wheel with out posi that I can slap right in. My question is, which would you get and why? They are the same price.
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds |
11-17-2013, 11:57 PM | #2 |
Re: 14 bolt conundrum
Get the one with the locker. If it is a true 1 ton srw then it is the same a le as the 3/4 ton ff.
11-18-2013, 03:06 PM | #3 |
If I were to get the 3/4-ton rear I would have to move the perches and I am pretty sure, swap the shock mounts to the other side. If I were to get the 1-ton rear all the mounts and perches are where I need them and could just slap it in with some mods to the parking brake.
11-18-2013, 03:46 PM | #4 |
Personally, I would go with the 1 ton unit because it will have bigger brakes than the 3/4 ton unit, and I have had bad experiences with Gov-locs when the clutches start to disintigrate. you just don't know what condition the Gov-loc is in when you buy a used axle.
11-18-2013, 05:07 PM | #5 |
cleszkie....That is what I was thinking but wanted as much feedback as possible to try to make the right decision.
11-18-2013, 05:47 PM | #6 |
Are the 3/4 and 1 ton axles out of the ssame generation of truc (73-88 or 89-98)? If so i believe the mounts are the same. Also, every 3/4 full floater i have worked on had the same brakes as a 1 ton. Basically a 14 bolt full floater is a 1 ton axle. There are two different widths. One ton srw, dually and 3/4 tonare the same. 1 ton cab and chassis is narrower.
11-18-2013, 10:05 PM | #7 |
I agree with that statement. For what it's worth, pick the one that's going to go in the easiest with the least amount of fab.
1972 chevy k20 long bed 4x4 1990 chevy K5 blazer 2001 chevy 2500 hd 4x4 1999 chevy 1500 4x4 |
11-18-2013, 10:30 PM | #8 | |
I would avoid the gov-loc too, though the ones in 14bolts are better than the half ton units.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-19-2013, 01:33 PM | #9 |
1 ton
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
11-19-2013, 04:54 PM | #10 |
Thanks everyone. I am going to get the 1 ton.
11-19-2013, 08:41 PM | #11 |
Currently Blazerless
There were 3 different brake sizes on the 14 bolt, early years had small drums and are popular with guys that want to run 15" wheels on a full floater. The mid 70s on up used 2 different sizes on 3/4 ton with the 13 drum being the biggest and all 1 tons got that size. The 3/4 ton, 1 ton SRW and 1 ton C&C all used the same axle housing and axle shafts with the differences being in the hubs and backing plates. 1 ton DRW had a wider housing than the rest but used the same hubs as the C&C.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
11-21-2013, 12:18 PM | #12 |
SO I have another question. If the price was right, would you purchase both and swap the govlock into the 1 ton unit and then sell the 3/4 ton unit so I could have some sort of traction control?
