11-21-2013, 10:19 AM | #1 |
Best aftermarket engine mounts?
Hey Guys,
I am planning a crate engine engine swap into my '72 (350, 2-piece rear main seal...not and LS engine). I'd like to replace my engine mounts and I've heard that direct GM ones are a little pricey. What are the best aftermarket engine mounts? Thanks for the input, Guys! Chris |
11-21-2013, 12:06 PM | #2 |
Re: Best aftermarket engine mounts?
Any auto parts store will have what you need for 20 bucks a piece or less. You'll just need to be year specific as far as mounts go. If possible, take an old one into the store with you! 9 times out of 10 its a college kid giving you parts from what the computer tells him to. A good parts guy is hard to find these days! Just tell the guy you have a 72 with a sbc. I'm pretty sure all truck mounts are the same for sbcs in the older trucks. However the mounts changed a little from cars. The car mounts are an oval looking creature.
11-21-2013, 12:17 PM | #3 |
Yeah, I didn't know if there were any brands that were better than others...Moog, etc?
Thanks! Chris |
11-21-2013, 12:21 PM | #4 |
If you can get moog from the local guys then that would be ideal. As far as spending a ton of money on them... thats up to you. The only motor mounts I've ever seen worn out were 20+ years or older. Personally I'd get what I could afford comfortably. I wouldn't break the bank on them.
11-21-2013, 04:47 PM | #5 |
My 383 destroyed 2 sets of oe $30 mounts in the first 3 months. The rubber was just junk . I now run Prothane mounts
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
11-21-2013, 04:53 PM | #6 |
2WD Jimmy
11-21-2013, 05:45 PM | #7 | |
11-21-2013, 06:53 PM | #8 |
Dam! I suppose I haven't bought motor mounts in a while. I was running high strung bbcs through mud pits and never once had one fail! I didn't know they were being made so ****ty. Glad someone else chimed in here, cause I'm fixin to buy a set my self. However MOOG still makes good parts. I wouldn't hesitate at all with them. I just replaced my whole front end with MOOG parts and they are top notch.
