Old 11-21-2013, 07:27 PM   #1
dwcardfan
dwcardfan's Avatar
What radiator to use in 65 chevy ls swap
I need some help deciding what radiator to use in my 65. I am putting a 5.3 and 4l60e out of a 2000 silverado. Post some pics and ideas.
dwcardfan is offline   Reply With Quote
Old 11-22-2013, 03:07 PM   #2
Matt Cramer
Re: What radiator to use in 65 chevy ls swap
I just used my stock radiator in my '72. A set of 2005 Silverado coolant hoses plumbed right up - except I had to shorten the lower hose about an inch on each end.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 11-22-2013, 04:10 PM   #3
dwcardfan
dwcardfan's Avatar
Thanks for the input. My truck did not come with a radiator so I will have to buy one.
Old 11-22-2013, 04:42 PM   #4
Clyde65
Clyde65's Avatar
I used a Champion Radiator. works very well and lifetime warranty
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-22-2013, 04:53 PM   #5
JJH Jimmy
JJH Jimmy's Avatar
I used an Entropy on my swap in my Jimmy and am happy with it. Here is a link to their 63-66 radiators.
http://www.entropyrad.com/radiators/...ck/cat_25.html
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 11-23-2013, 10:27 AM   #6
dwcardfan
dwcardfan's Avatar
Hey Clyde65 I was wondering if you had any pics of your radiator. Looks like champion might be a little cheaper.
Old 11-23-2013, 09:30 PM   #7
BigDan3131
BigDan3131's Avatar
I'm doing it on the cheap because I can fab things and because I have a pair of Spal fans already. This is the radiator I plan to use:http://www.summitracing.com/parts/gr...make/chevrolet and I might be getting it cheaper now that my work has a wholesale account with A tech which is part of Summit.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-24-2013, 06:25 PM   #8
Clyde65
Clyde65's Avatar
I don't have a picture right now, but it fits in the stock location with the stock mounts, you will need to trim the runmbber just a bit because the champion is more square that a stock one.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-24-2013, 09:58 PM   #9
dwcardfan
dwcardfan's Avatar
Thanks for the information. Does yours have a shroud and electric fan?
Old 11-25-2013, 09:06 AM   #10
Clyde65
Clyde65's Avatar
No, I dont have a shroud but I do have two 11" electric fans that came with the radiator. One is on when temp reaches 195 and the other comes on when AC is turned on or it reaches 210. both are pullers.
I found a couple pictures, I hope this helps...
Clyde65
Rebuild of Clyde
support our troops!
Old 11-25-2013, 01:28 PM   #11
dwcardfan
dwcardfan's Avatar
Thanks clyde65 for the pics looks good. Where did you order it and what are the specs on it? Thanks for all your help.
Old 11-27-2013, 07:39 PM   #12
Robznob11
Robznob11's Avatar
I ordered one off of ebay to fit an 02 vette, it has oil and trans cooler and warrenty for 100$ not a direct fit but easy to fab two brackets out of aluminum strap to hold top two screws hold bottom. And im running a dual fan set off a v6 camaro wich i got for 20 bucks at the salvage along with a coolant overflow tank off a 02 cavileer. My truck idles at 197 on a hot day.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 11-27-2013, 11:27 PM   #13
dwcardfan
dwcardfan's Avatar
Thanks Robz for the post. I will check into that. Do you have any pics of your install?
Old 11-28-2013, 01:54 AM   #14
Robznob11
Robznob11's Avatar
Smile Re: What radiator to use in 65 chevy ls swap
you can see from the pic that there is two plastic tits on the top that I made simple brackets to hold down and in place. there are two more just like that on the bottom and they are hollow. so I drilled two holes through the bottom of the support and then put 1/2" #8 screws with nuts and lock washers through them that stick up. I just slid the bottom tits over the screws and then locked the top in place. the Camaro fans are the exact size to fit the vette radiator there is like one small plastic piece that needs to be trimmed for them to attach and they are mounted pretty much like gm made them for the radiator. I trimmed the lip off my support so the radiator would sit further forward but only to clear the air cleaner. you may not need that. top hose is a stock truck hose (4.8/5.3/6.0) bottom I will have to look at the # but it is like a 1 1/2 on the pump side and 1 9/32 on the radiator side. these pics are old but I now have my steam hose tee'd in between rad and bottle. and I have a hose from 5/8 wp (heater core outlet) up to bottle back to the 3/4 side of wp(hco). I understand yours is an earlier year model but I bet it could be made to work fairly simple...
LED TAILS
Old 11-28-2013, 10:18 AM   #15
dwcardfan
dwcardfan's Avatar
That is a clean install. Thanks again. I am not sure if there is room under the hood of my 65 or not. I am keeping my inner fenders. I will have to measure to make sure there is enough room.
Old 11-28-2013, 02:01 PM   #16
Robznob11
Robznob11's Avatar
well those tits are about an inch tall another way to mount it would be drill 1/2 holes through the bottom that the tits could drop through then cut the top ones off and run a flat c syle clamp to save a few inches. this radiator is a little shorter and about 6-8" narrower than the stocker (67-72) and only about 2" thick. measurements are on the web site. I went this rout so I did not have to run separate coolers or block off to get it running. and if found that the stockers are good enough. with fans installed its probably not much thicker than a stocker. lol ill try and get some more pics for ya
LED TAILS
Old 11-28-2013, 02:38 PM   #17
dwcardfan
dwcardfan's Avatar
What are the outside dimensions on your radiator?
Old 11-28-2013, 04:41 PM   #18
Clyde65
Clyde65's Avatar
I have the cc284 and I ordered from Championradiators.net
My dad has one in his crew cab also
Clyde65
Rebuild of Clyde
support our troops!
Old 11-28-2013, 04:47 PM   #19
dwcardfan
dwcardfan's Avatar
Did you get your dual fan setup from champion too?
Old 11-28-2013, 09:39 PM   #20
Clyde65
Clyde65's Avatar
Yes
Clyde65
Rebuild of Clyde
support our troops!
Old 11-29-2013, 10:33 AM   #21
dwcardfan
dwcardfan's Avatar
Thanks! On champions website it just had cc284 with a 16 inch radiator.
Old 11-29-2013, 02:37 PM   #22
Clyde65
Clyde65's Avatar
I saw that, I would call them and ask if you could get dual 11" fans.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-30-2013, 01:19 AM   #23
Billett
Billett's Avatar
Pro performance is a vendor here and is doing a black Friday sale on champion rads. I just got one for my 68.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 06-11-2014, 12:45 AM   #24
66LSx
66LSx's Avatar
Anyone know anything about this? Stumbled on it... but its not searchable thru the site but I forced the part number from TR65's pictures...
http://www.summitracing.com/parts/gri-6-563ar-jax
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 06-11-2014, 01:17 AM   #25
littlevictories
nope, that's brand new.
I used a griffin for a ls-swapped 69 camaro. bolted right in
just kidding, it took a 3-4 hours fab works and parts store running.
both water outlets are on the pass side so no long hose runs and lots of extra room.
littlevictories is offline   Reply With Quote
