Old 11-19-2013, 04:28 PM   #501
TJ's Chevy
TJ's Chevy's Avatar
Re: Donz '65 SWB Stepper Budget Build...
Nice progress! Keep it up! Hood is looking good.
Old 11-21-2013, 11:30 PM   #502
Jmorales3181
Jmorales3181's Avatar
Originally Posted by Ta2Don View Post
Hey Jmo, and any other body guys who care to add input, I have a quick question or 3 about glazing putty… Jmo is this the putty you referred to?
Is it a 2 part mix like Body filler, and what grit paper would be best for smoothing out once the putty is cured? And finally, would I just need regular primer over these spots before paint? Thanks for your input guys!!!
All this is new to me and leaving me a bit
That's the stuff it's. 2 part mix. And I usually start with like 100 grit paper to take down the high spots or not so smooth edges and then block with 180 then feather around with 220 and 300 and then sometimes 400 grit. I'm not a huge fan of the primer will fill it method I like to be able to make my bodywork smooth enough to seal it if I had too. I usually use an etch primer first for any bare metal any larger than the size of a nickel. Then a few coats of high build primer and some guild coat then block with 400 and then 600 and paint....hope this helps
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 11-22-2013, 09:17 AM   #503
clemdaddy
clemdaddy's Avatar
yeah don, jmo does it right... and thats the glaze i use too. he does a little more fine grit sanding steps than me but now i know one of his secrets, mine will turn out better. thanks jmo, and thanks don for making good progress and posting up often.
clemdaddy is offline   Reply With Quote
Old 11-22-2013, 12:30 PM   #504
Ta2Don
Ta2Don's Avatar
Thanx JMo!!! that clarifies and erases some of the I've been experiencing...
Thanx Clem for the encouraging and affirming words!
As for posting often, sometimes it is a bit too often for my wife...
I look up from the screen to see her albeit a bit too late...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 11-22-2013, 12:34 PM   #505
Ta2Don
Ta2Don's Avatar
Thanks TJ...
With JMo's tips, I'm hoping to get this hood finished, painted , and installed in the next 2 weeks...
This weekend I've got to tow the boy's Volvo home to diagnose engine issues...
Monday will be tied up with Dr. Appt for my Beautiful Bride!
and some of the best Pizza in the state...
Laterz for now!!!
DON
Proverbs 27:17
Old 11-24-2013, 09:12 PM   #506
Ta2Don
Ta2Don's Avatar
In Post #499 I mentioned that I was planning on some Steering Wheel work during this past work week... well, seems my dremel tool went missing, so I spent the week scratching my head, trying to remember last place said tool was seen...
After digging around and moving other tools, wa la… it was buried under my framing nailer, hiding in the dark recesses of the black box the nailer was residing in...:wash:
Now that it re-emerged, time for some wheel work… Here are some pics before the actual work begins…
Plans are to use the dremel to grind out the cracks and fill with epoxy then paint…
Any tips or suggestions are welcome, I haven't repaired any steering wheels in the past...
DON
Proverbs 27:17
Old 11-24-2013, 09:28 PM   #507
Ta2Don
Ta2Don's Avatar
One of our own has passed away… Greg (Kart34)
Here's a link to a thread concerning this…
http://67-72chevytrucks.com/vboard/s...d.php?t=605524
DON
Proverbs 27:17
Old 11-25-2013, 09:08 AM   #508
clemdaddy
clemdaddy's Avatar
don't know how others approach the steering wheel cracks but i do it sorta like fiberglass repair. i take an x-acto knife and cut a V in the scratch about 1/16 inch wide then cut a deeper reverse ^ as best i can. which make an hourglass shape where the crack was. mix up jb weld and push the mix into the cuts. it will shrink up a bit but should lock the crack so it won't reappear. another coat of jb should get it pretty flush and after that its bodywork.
theres probably other and better ways but thats just my way...
have a nice holiday this week my friend and stay warm...
Old 11-25-2013, 10:30 AM   #509
pdxhall
pdxhall's Avatar
I've only done one so far but I did mine pretty much the same way as clemdaddy.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-25-2013, 02:40 PM   #510
Ta2Don
Ta2Don's Avatar
Thanks for the input guys...
Going to start in on the wheel today...
DON
Proverbs 27:17
Old 11-26-2013, 09:21 PM   #511
Ta2Don
Ta2Don's Avatar
Epoxy has been sanded down…
Now time for finish sanding and paint…
Coming Soon!
DON
Proverbs 27:17
Old 11-26-2013, 09:59 PM   #512
TJ's Chevy
TJ's Chevy's Avatar
Looking good!
Old 11-26-2013, 10:06 PM   #513
NEWFISHER
NEWFISHER's Avatar
Good work on the wheel. I use the same process. The last one in the 65 I used a 2 part panel adhesive or epoxy as I was out of JB weld. It worked great, no shrink back. Primed it, sanded it, sealed it and the base cleared it. Wet sealer, wet base wet clear..no dry time in between. Let it sit 24 hrs and all good.
NEWFISHER is offline   Reply With Quote
Old 11-27-2013, 11:45 AM   #514
jlsanborn
jlsanborn's Avatar
Looks great! I used JB on mine and found that a little bit of heat gun action kinda helped "wick" it into the cracks.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 11-27-2013, 10:42 PM   #515
Ta2Don
Ta2Don's Avatar
Looking good!
Thanx for the tips Guyz!!!
Have a Happy Thanksgiving!!!
DON
Proverbs 27:17
Old 11-27-2013, 10:52 PM   #516
likaroc13
Rollin' Old Skool
Need to fix my steering wheel too. I know it had some typical minor cracks, but I haven't looked at it in so long, I don't really remember what they look like. I know some companies (such as Eastwood) make a kit specifically for these kinda issues. I've seen others use JB weld as well, & it seems to do the job just as good. Nice work, & hope ya'll have a Happy Thanksgiving as well.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 11-27-2013, 11:03 PM   #517
65truckowner
65truckowner's Avatar
Looks good should be real nice once you get some paint on it.
65truckowner is offline   Reply With Quote
Old 11-28-2013, 12:00 PM   #518
dwcardfan
dwcardfan's Avatar
Looks good. Keep the updates and pics coming.
dwcardfan is offline   Reply With Quote
Old 11-28-2013, 12:18 PM   #519
TJ's Chevy
TJ's Chevy's Avatar
Old 12-01-2013, 06:17 PM   #520
Ta2Don
Ta2Don's Avatar
Not too much accomplished today… other than some Honey-Do's...:wash:
I did get some sanding and primer on the wheel…
Once the primer was applied I spotted some areas that need attention...
Will be steady on it, plan on painting by Wednesday...
Weather forecast beyond that is Cold and Nasty! and my paint area is not heated...
Stay Tuned!
DON
Proverbs 27:17
Old 12-01-2013, 06:22 PM   #521
Ta2Don
Ta2Don's Avatar
Not sure why the latest pics posted are clickable thumbnails???
Here's a teaser peek at my Sail Panel that I plan on modifying… Plan to add to the lettering...
[IMG=http://imagizer.imageshack.us/v2/150x100q90/c/542/mhf4.jpg][/IMG]
Imageshack changed their links… So I either get a clickable thumbnail or a clickable link...
DON
Proverbs 27:17
Old 12-02-2013, 06:33 PM   #522
Grizz1963
Grizz1963's Avatar
Parcel landed from Arkansas today......
I am not going to post up my ugly mug, but Thank You Don for the Griswold T-Shirt and the hand carved smoking pipe you sent for Nicola's collection.
Thanks for the call earlier, hope the paint is on by now.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-02-2013, 08:59 PM   #523
TJ's Chevy
TJ's Chevy's Avatar
Nice work on the steering wheel! Now for paint!!!! IF it isn't on already! lol!
Old 12-02-2013, 09:52 PM   #524
Ta2Don
Ta2Don's Avatar
Thanks Guys!
Painting has started
More color tomorrow, then tape off the accent areas to spray white… then on to the matte clear coat...
More Pics once the clear is on...
DON
Proverbs 27:17
Old 12-02-2013, 09:58 PM   #525
Ta2Don
Ta2Don's Avatar
I also tightened up some areas on the practice hood...
Should have this in Paint within a week…
gots me a game plan to heat my paint area...
DON
Proverbs 27:17
65 swb, c10, step side, tattoo
