Old 11-20-2013, 03:44 PM   #1
72mistressc10
72mistressc10's Avatar
Need Grill Pictures
I am currently attempting to attach the egg crate grill tabs to the outer grill tabs using the plastic clips and screws that go into the plastic clips.
Can someone please post a picture of how this is configured, which way the clip goes into the two pieces, which way the screw goes into the clip?
Thanks!
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline   Reply With Quote
Old 11-20-2013, 08:30 PM   #2
72mistressc10
Re: Need Grill Pictures
Anyone
Old 11-21-2013, 01:53 AM   #3
Dm1pfoy1
Dm1pfoy1's Avatar
Outer grille>>>>egg crate>>>>clip(comes in from back of egg crate to attach to outter)>>>>screw if some one has digital version of manual its chapter 13-3 figure 4.-grille mounting in 71 service manual
Project Fast 'n' Loud
72' C10 SWB Fleet, Faux Patina, 383 ci stroker
The Page: http://67-72chevytrucks.com/vboard/s...d.php?t=608214
Dm1pfoy1 is offline   Reply With Quote
Old 11-21-2013, 01:54 AM   #4
Dm1pfoy1
Dm1pfoy1's Avatar
I dont know how much it helps but with th350 getting about same mpg on 383. Have you looked at borg warner manual trans like t10 or super t10 they are very similar design to muncie with lower $$ gives you the manual trans you want with a wide selection of ratios. So in ideal world should work to give you all you want and keep cost low to make payoff sooner.
Old 11-21-2013, 01:56 AM   #5
Dm1pfoy1
Dm1pfoy1's Avatar
Sorry second post was from another thread phone messed up.
Old 11-21-2013, 10:35 AM   #6
72mistressc10
Thanks for this information, landed on http://67-72chevytrucks.com/vboard/s...d.php?t=558016 through a google search, what a life saver.
Thanks!
Old 11-21-2013, 11:57 PM   #7
72mistressc10
Ok so I was able to download the document, the instructions make sense but I am unable to put the plastic clip through the outer grill portion.
Any tips or tricks for a newbie would be greatly appreciated!
