10-27-2013, 09:45 AM | #1 |
New GMPP Fast Burn 385 Roller Cam
Brand new roller cam. I bought a GMPP 385 (technically bought the ZZ430 from paceparts.com) and have this roller cam for sale. They installed the hot cam for me prior to shipping the motor, along with the 1.6 roller rockers-that's what they call the ZZ430. It is the cam that comes in the 385 fast burn with aluminum heads. This has never been ran, taken out of crate motor and swapped out for the hot cam. This is a brand new roller cam with mechanical fuel pump lobe. Here's the specs.
GMPP hydraulic roller camshaft has a .474 in. intake lift and a .510 in. exhaust lift with 208 degree open duration intake and 221 degree open duration exhaust lobes at .050 in. ground with a 112.5 lobe centerline. * Camshaft type (P/N 10185071): Hydraulic roller * Camshaft lift (in): .474 intake / .510 exhaust * Camshaft duration (@.050 in): 208° intake / 221° exhaust sells for $239.97 through summit, i'll sell it for $165 shipped http://www.summitracing.com/parts/na...5071/overview/ if you've been thinking about a roller cam build, this would be the cheapest way to go |
10-29-2013, 07:01 AM | #2 |
Re: New GMPP Fast Burn 385 Roller Cam
bump
10-29-2013, 10:08 AM | #3 |
I am very interested in the cam, but I have to do a little more research. Are the posted numbers with 1.5 or 1.6 rockers?
10-29-2013, 01:45 PM | #4 |
11-01-2013, 05:49 PM | #5 |
bump
11-02-2013, 11:10 AM | #6 |
Interested. Is this for retrofit roller cam install or blocks manufactured with oem roller cams?
11-02-2013, 11:14 AM | #7 |
According to the summit website its for use in factory roller cam blocks 85-96. I am running vortec heads and have to consider modifying them for the higher lift this cam has
11-02-2013, 11:26 AM | #8 |
I would like to offer $150 shipped.
11-02-2013, 04:10 PM | #9 |
11-03-2013, 12:57 AM | #10 |
Ill take it
11-03-2013, 09:13 AM | #11 |
$150 payment sent as per pm
11-03-2013, 11:08 AM | #12 |
11-22-2013, 11:14 PM | #13 |
I got the cam a while back just forgot to update. Thanks again.
