Old 10-28-2013, 06:10 AM   #1
ItWillBeSlow
ItWillBeSlow's Avatar
Radio Delete Clips
Does anyone make these things aftermarket/reproduction?
Thanks!
ItWillBeSlow is offline   Reply With Quote
Old 10-28-2013, 06:35 AM   #2
roger pickens
roger pickens's Avatar
Re: WTB Radio Delete Clips
what is a radio delete clip?
roger pickens is offline   Reply With Quote
Old 10-28-2013, 06:39 AM   #3
ItWillBeSlow
Clips that hold on the radio delete plate for non-radio trucks.
Old 10-28-2013, 06:46 AM   #4
roger pickens
Re: Radio Delete Clips
ok havent seen those before but i would fill the hole with a radio but thats me
Old 10-28-2013, 06:52 AM   #5
ItWillBeSlow
I'd be glad to do that, will you spot me a few hundo?
Actually, mine does currently have a radio in it, but its non working, ugly, and I have plenty of other things to do to the truck before it gets fixed up. I just want to put the plate on now to get some wiring and junk out from behind the dash.
Old 10-28-2013, 07:09 AM   #6
roger pickens
understand! but any money i had is in my 70c10. its a daily driver and the first thing i had to have some jams. good luck with your project
Old 10-28-2013, 10:28 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
To the best of my knowledge they are not reproduced.
LockDoc
Leon
Old 10-28-2013, 11:24 AM   #8
ItWillBeSlow
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Heres another dumb question, what do these clips attach to? It looks like there would have to be a bar of some sort right in the radio hole. I do not beleive mine has that (radio in currently)
Old 10-28-2013, 11:28 AM   #9
allons
The clips rotate with the radius that slides up under the metal edge that has been rolled over on the cover. On the clip is 2 spring clips that are formed at 90 degrees to the slide pieces and those clips are supposed to pop into the 2 round holes in the dash.
If you find a source for the clips, let me know because I've only got 1 clip also.
allons is offline   Reply With Quote
Old 10-28-2013, 11:42 AM   #10
ItWillBeSlow
2 round holes in the dash... is this something mine will have once I remove the radio thats in it? Im starting to think not, and I wouldnt be able to even put my plate on even with the radio removed. I had originally thought the clips would fix the plate to the dash on the outside edge. Do you guys know if I am missing something paintfully obvious right now? I wont be back to the truck for a couple weeks so I can't run out and check it right now.
Old 10-28-2013, 11:58 AM   #11
LockDoc
LockDoc's Avatar
If your radio hole has been cut out for a later style radio the delete plate will not work. The original radios have a rectangular hole for the faceplate and a round hole for the knobs to stick through on each side.
LockDoc
Leon
Old 10-28-2013, 01:08 PM   #12
allons
That is correct. The original (radio delete) dash had a small rectangular hole with 2 round holes on each side. The radio delete plate covered the entire area and the clips popped into the 2 round holes.
Some dashes have been altered over the years by hacking and wacking to install different radios.
Old 10-28-2013, 05:57 PM   #13
Sillyoldman
#16876
Sillyoldman's Avatar
I'd bet a couple of modified Butterfly molding clips and a homemade cross brace would fix that up pretty easily.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 10-28-2013, 07:38 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by ItWillBeSlow View Post
2 round holes in the dash... is this something mine will have once I remove the radio thats in it?........
Here's a pic I took of my cup holder when I had the radio off. It shows the stock radio openings.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-28-2013, 08:19 PM   #15
ItWillBeSlow
Thanks a lot for the responses guys, lots of help.
I think I may still be good. 68gmsee, that pic is exactly what I needed to see to get my dumb slow brain to understand how they clipped in. Thanks!
Old 10-29-2013, 10:27 AM   #16
74baggedbug
How about using a thin magnet to hold it in place???
74baggedbug is offline   Reply With Quote
Old 11-22-2013, 11:36 PM   #17
ItWillBeSlow
Anyone tried this or any other quick/easy remedies to get the plate in place without clips?
Old 11-23-2013, 11:13 AM   #18
Sammy
High strength Velcro strips @ your hardware store would work without breaking the bank.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-23-2013, 11:16 AM   #19
midniteblues
midniteblues's Avatar
i've used magnets before i had the clips.
radio shack has a good selection of magnets
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
