Old 11-23-2013, 12:10 PM   #4
bwood
bwood's Avatar
Re: Dreaded P0300 P0308 & P0341 Error 1999 Sub C1500
Originally Posted by shultzee13 View Post
C1500 suburban had a miss in it after I changed spark plugs, wires cap and rotor.
So the miss started after the service? Check the plug wires, the cylinders are 1, 3, 5, 7 on the drivers side, 2, 4, 6, 8 on the passenger side (front to back). It is not the same on the distributor. There is nothing on the distributor to adjust, there is only a cam sensor, but he cap does need to come off to verify it is line up properly with TDC. The code for a distributor that is not set right is P1345 (camshaft/crankshaft correlation error).
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
