Old 11-23-2013, 04:16 PM   #1
54blackhornet
54blackhornet's Avatar
GMC Grill InterChange Question ?
I am building a 71 K-10 I picked up this summer, pulled the front clip, cab and bed yesterday. The core support is shot, so I am thinking about converting it to a GMC, will a 68 GMC grill mount onto a 71 GMC core support ? Thanks Guys
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-23-2013, 04:26 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: GMC Grill InterChange Question ?
I have never done exactly what you asked but i did do a body off resto on a 71 gmc (my profile pic) and my understanding is all gmc core supports are the same.
WIDESIDE72 is offline   Reply With Quote
Old 11-24-2013, 12:45 PM   #3
54blackhornet
Thanks for your input, My concern is with the difference in the 67-68 core and the 69-72 core ? I have a perfect 71 GMC core and a good 68 GMC grill, was planning on marrying the two. I know the early GMC cores are different then the later ones . Any help would be great ! Thanks guys
71 C-20
07 Magnum RT AWD
Old 11-24-2013, 01:07 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Captain Obvious says if you have both then go try it!
Old 11-24-2013, 03:00 PM   #5
john
member #16
john's Avatar
GMC Pauls has 67-68 and 69-72 supports. The only difference I can think of is the 67-68's have mounting holes for the splash pan, which 69-72;s don't use.
john is offline   Reply With Quote
Old 11-24-2013, 04:13 PM   #6
54blackhornet
Thanks Guy's I knew about the early splash pan not being used on the later ones, just not sure if the grills are different ? I want to use a 68 painted grill on a 71 core,fenders and hood.
71 C-20
07 Magnum RT AWD
