Can't decide between 5.3 or 6.0
Originally I wanted to do a 5.3, then a 6.0. Now I want to do a 5.3 again.
![]() Thoughts on this? Thanks!
71 K20 64 GMC mud truck |
![]() Join Date: Aug 2004
Re: Can't decide between 5.3 or 6.0
That is a question everyone deals with, it's all up to you.
Is this a daily driver? I think with either the MPG will be pretty Close and the how I'll be like you said pretty close, the torque might be the only real difference.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Well, when I get my license it'll be my DD for a while until I get a second car. After that though the truck will probably get driven pretty regularly. My dad's got a 99 Silverado with a 5.3, 250k miles, and that thing still gets 19 mpg. My 350 currently gets around 13 mpg, so if I could get 16-17 out of it I'd be happy. I understand that these trucks have the aerodynamics of a brick so they won't quite pull off 20 mpg.
Truck and auto performance nut
you only need to go for the 6.0 if your looking for all out power....as in for towing or racing, etc. Oh.....and only 30hp difference? Not in tuned form!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Basically what I'm looking for is something that has good strong power, while still being reliable and getting good MPG. 5.3's and 6.0's get such mixed reviews, that it makes it even harder to pick.
well I like the 6.0 because it has the bigger pistons and can run the larger heads if you want to in the future! also any upgrade magnifies with the larger displacement! imo most people cant ever stop adding once they get started, I mean its like you can never get enough. If you buy a 5.3 you put a cap on how far you can go. and lets face it a cam in a 5.3 is awesome but the power in a motor is found in the heads so why limit how big you can go in that area. fyi incase anyone is wondering because the cylinders are smaller you run into valve shrouding problems.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Now I can't decide again
Keep in mind, you can take a 5.3 and bore it over to run 5.7 pistons and gain a little more bore size. Personally for your situation I'd say go 5.3 with a cam and usual bolt ons and supporting mods with a full custom tune.
I'm in the same boat. Started out with a 5.3, then 6.0. I'm now back to a 5.3 to get the swap done and truck on the road. Then I plan to build a 402. For the price to buy a jy 6.0 and mod, it's not much more to build a new stroker assuming you have all the little nickel and dime stuff to begin with.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
meowMEOWmeowMEOW
You said "When I get my license"...
get a 5.3; it will give you plenty of power, for someone who has little experience behind th wheel. I don't even mean that in a belittling way, just that its the truth. With a cammed 5.3 you'll be somewhere in the middle 3's for horsepower, and torque to match. Combined with the way these old trucks feel going down the road, it will easily be the top end of what you can handle. Too many people are focused on building big numbers, yet have never driven their vehicle to the edge of what they already have. Get the 5.3, toss a cam in it and have it tuned. It will make you plenty happy and give you the feel, sound, and even some efficiency to still be a useable DD. Drive the heck out of it, find where the edge of traction is, find where the edge of steering is, and drive it to that edge (safely). Then, when you've conquered the truck as it is, build it up. You'll appreciate the gains in power more, and you'll also be a better driver overall for it. I'm not one to say young drivers should only have uber-safe-slow cars, as I think driving something with some real nuts forces you to learn to drive correctly. These old vehicles require focus, and some effort to drive unlike modern vehicles, and they teach you way more about driving in general. You can have just enough power in that truck with the 5.3 to haul ass, win a few friendly wagers with friends, tow a high school parade float, and still squeak out ~16 combined mpg so you'll have money left over for condoms.....no one wants to be the guy dropping a girl off at 10pm, cuz he only had money for a few gallons of premium...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jun 2006
Heck you can get the little 4.8L and just add a non-intercooled turbo to it for the extra torque and still knock down decent mpg. Its not so much that our trucks are bricks as much as vehicle weight. With a 2 wheel drive we can lower it quite a bit to reduce drag and getting rid of weight you don't need helps too. But with a 4x4 you have more drivetrain loss, the height is higher and the tires are bigger and heavier.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Location: Sunny, Florida, some might call it South Alabama
I have a 6.0 with a 4L60e and the rest of the mods I'm running are in my sig. But my gas mileage is around 10-12 and once I've gotten 15 mpg.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
Always a work in progress
Get a 5.3 learn it and when its time to get more power then throw a turbo on it and let it rip. nuff said lol!!
Seriously though, 5.3s are plenty powerful when tuned right. I love mine. Don't try and start with high HP, like BR3W CITY said you will appreciate the power you gain more.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#14 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 | |
Lots of great advice here guys. I've been driving since I was about 7, driving vehicles since I was 9, but I've never really driven faster than 10 mph
![]() I guess 5.3 it is. Unless I get a killer deal on a 6.0. Probably won't happen though, as 5.3's go for around $6-700 and 6.0's go for around $1000. I suppose that if one day I do decide to do a 6.0, it'd almost be a bolt in deal as the harness and whatnot would already be done. Quote:
![]() Thanks for helping my make up my mind! Although I'm sure it'll change 800 times between now and then. ![]() ![]()
#16 |
I was going to recommend a 4.8 but I noticed in your sig that you have a K20, so I will pull that back and mimic what these fine folks have suggested.
#17 |
Yup, the truck weighs 5000 lbs, more like 6000 with me in it.
#18 |
5.3 is your choice and don't be fooled about less cubes the 5.3 can be resleeved and made into a 427 from erl but its gonna cost a pretty penny
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold 2003 1500 Silverado - Selling 2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LB SRW |
#19 | |
That's my dream motor.....something similar to the LSX454 but in a 427ci just for kicks. LSX427......I like it. Some day.
#20 |
#21 |
The 5.3 is a great motor, even towing and hauling loads. Very available. You can pretty much get your money back if you change your mind later and want the 6.0, or whatever new LS engines out later. Love mine.
#22 |
Here is my 5.3 with 6L80 I just got running, not the fastest thing in the world but it gets up and moves....and I still need to get it dyno tuned!
https://www.youtube.com/watch?v=WONDIfhAOiI |
#23 |
I don't think it'll take much to go faster than my truck.
#24 |
Nope, nothing done to the engine except tuned to run as a stand-alone. I will be getting dyno tune in the future to squeeze all available hp an d tq out of it!
#25 |
Now that is impressive!
