Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-27-2013, 02:04 AM   #1
JPBrecheisen
1960-66 Big Truck Rubber Floor Mat
I thought I might post this just in case anybody else wanted to have some info.
I recently started cleaning up my 1960 C60 Viking. It didn't have a floor mat in it, and reproductions are not available for the big trucks. The fitment can be a bit of an issue since the transmission access panel (tunnel, hump, whatever you call it) is fairly flat with minimal rise.
I did some research and found one that I thought might fit pretty well for my truck. Its not "exact", but I think it turned out pretty nice for an item that is intended to be used in a different truck.
I used the floor mat that is supposed to fit a 67-72 model year truck with the small hump. I noticed those trucks had a really low transmission tunnel cover and I know the cab dimensions as far as floor pans etc. were pretty close. It took a little tugging and stretching hear and there, but I am happy with the results.
I ordered the mat from Classic Parts Part No. 39-033.
The shop was dark, but here are the photos of the almost completed installation.
Jonathon
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 11-27-2013, 08:53 AM   #2
Katrina/10
Katrina/10's Avatar
Re: 1960-66 Big Truck Rubber Floor Mat
That fits pretty well!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-27-2013, 10:51 AM   #3
68panelman
68panelman's Avatar
Not bad at all. Good job.
68panelman is offline   Reply With Quote
Old 11-27-2013, 07:53 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looks good!
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 11-27-2013, 11:42 PM   #5
JPBrecheisen
Thanks Everybody.
I am happy with the way it turned out.
Old 12-23-2013, 02:36 PM   #6
Carl Spangler
Carl Spangler's Avatar
What did you think of the quality of the 'rubber' material?
thanks
JohnG
Carl Spangler is offline   Reply With Quote
Old 12-23-2013, 02:58 PM   #7
68panelman
68panelman's Avatar
Yours looks like the same pattern as oem. There's a lot of threads about the quality of the after market material failing within a years time. I managed to buy soft pliable originals from the parts for sale on this forum. Mike.
Old 12-23-2013, 11:50 PM   #8
JPBrecheisen
thanks
JohnG
Well, "good" is subject to personal opinion, but I am happy with the quality. I used one from classic parts before in my 72 K25. That particular mat was purchased around 2004 and it has been just fine. It does have a small amount of very fine dry rot splitting in it in certain areas if you look really close, but no tears or cracks. The fit on that one was really good too. I had good luck with that mat, so that's why I went with classic parts on this one.
I think its a good quality for what I paid for it. I plan on buying one from them for my 62 when I get to that point.
I hope that helps.
Jonathon
Old 12-24-2013, 12:03 AM   #9
Carl Spangler
I hope that helps.
Jonathon
Thanks for the detailed response!
cheers
JohnG
Old 12-24-2013, 07:46 AM   #10
3v0
Thanks Everybody.
And you should be. Looks great.
3v0 is offline   Reply With Quote
Old 03-11-2026, 12:28 AM   #11
Pick121
Pick121's Avatar
Parking brake boot?
Jonathon
Hey Jonathon, Resurrecting an old thread but where did you get your parking brake boot? Is it NOS or part from another truck? Having zero luck finding GM part 3766218 boot for my ‘63 C50. And thanks for sharing floor mat info mine for sure needs replacing!
-Pickman (Mike)
1964 C10 Fleetside LWB “George”
1963 C50 “Green Machine”
[SOLD] 2019 Silverado 2500HD
2020 Silverado 3500HD
My story (Welcome Page)
Pick121 is offline   Reply With Quote
Old 03-11-2026, 01:45 AM   #12
JPBrecheisen
Mike,
The parking brake boot in the pictures was in fact a NOS item.
While they were NOS, I could see why they were missing on most surviving trucks equipped with the handbrake. Others might have different experiences but the quality of the handbrake boot was relatively poor. The are very thin and have a very little accordion folds, so they don't flex with the movement of the lever as they should.
It's hard to see in the pictures but the NOS boot and hold down ring isn't actually fastened to the floor. I left the ring loose so it could just slide across the floor mat. I tried to do it the factory way but didn't have success.
If I were to do the project again, I would find a quality boot that is taller and thicker so that the hold down ring could be fastened to the floor and boot flex with full movement of the brake lever as designed.
Jonathon
Old 03-13-2026, 08:15 PM   #13
karlbenz
Mike,
Jonathon
How bout that gearshift boot? mine is taring up after 2 years
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 03-14-2026, 02:03 AM   #14
Pick121
Pick121's Avatar
Mike,
Jonathon
Thanks for reply JPB, I was afraid of that. I have been researching alternatives and will report back once I get a few options
-Pickman (Mike)
Old 03-14-2026, 10:31 AM   #15
JPBrecheisen
I'm pretty certain the transmission lever boot was a re-pop for a 60-66 truck. I most likely got that from one of the big box restoration sources like Parts of America, LMC or Brothers.
It fit decent enough. I never did a hold down ring with that one either. The fit of the hole was snug enough that it stayed down on the floor mat pretty well.
I have had the experience of the reproduction stuff not lasting very long. Especially if it sees any sun.
If I did the job again, I think I would just use the 67-72 boots and hold down rings. Those boots are available and the transfer case boot is nice and tall and does flex enough to accommodate the travel of the parking brake lever. I think they would fit nicely and functional.
