![]() Join Date: Nov 2013
Re: What did you do to your truck today!
Took windshield & rear glass out of the 68. I found a little rest in the top of windshield. Ground out the minor rust, ( in the seams ) Filled primed & painted
ready to have it install this morning. I'm also putting in a B&M sport shifter today. Next job will be to make an Alum overlay for my auto meter gauges. I still don't know how to post pictures !! Need help on that ![]() |
Havent drove it in 3 weeks been busy with other things. But did move it from the shop to the carport.
#3 | |
Old member
![]() Quote:
How to post Pictures. Once your on the post U plan to make scroll down to where it says manage attachements. Click on it. A pop up will appear. Click on the first browse and pick the picture off your computer. Then hit the upload tab. Once it uploads do it again for the next picture. U can do this 5 times on each post. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thank you for the info, This will be a Test
Old member
It worked!
Now for a little more info. Once U have a picture uploaded like the picture of you truck. Right click on it and a pop up will have a bunch of stuff in it. Bottom says properties, left click on it and a nother box pops up. It will have a address line copy it. Like this: http://67-72chevytrucks.com/vboard/a...1&d=1385567827 Then come back to a post on here are any other message boad and add [img][/img] to it and it will appear. Are click the picture Icon up top of the post ![]() ![]()
I received a call from the body shop, they have finished with the UPS-damaged fender. I will pick it up when the weather breaks. I'll try to get up before and after shots for you guys.
