Old 12-14-2003, 11:23 PM   #1
71swb4x4
71swb4x4's Avatar
Heater Fan Problems
Hey guys and gals
My heater fan hasn't worked right ever since I got my truck 2 yrs ago. Today I decided to see if I could tackle it. The blower would never turn on until I got the slider all the way to the right, and then it was really picky, you had to have the slider exactly in the right place.
Well, turns out I had a new switch for it in the glove box, nice surprise. I put the new switch in, now I have 3 speeds, and they all seem to work good, but they only turn on once I get the slider to the last third of its range.
This is my fourth 69 - 72, and I don't remember it being that way on my others. Is that the way it works? Or is there a way to adjust it so it works through the whole range?
I guess its not a huge problem, since it does work on all three speeds now, but if its an easy fix I would rather have it be proper.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-14-2003, 11:44 PM   #2
jhow66
jhow66's Avatar
levers
Check this switch--you did not say which lever but it must be the one that controls this switch as the others only control doors. Fan should work on all 3 speeds with all levers to far left. Adjust cable so it works this way.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-14-2003, 11:49 PM   #3
jhow66
jhow66's Avatar
Forgot to mention that I borrowed this picture from a post by rage'nrat638--hope he does not mind.
Old 12-14-2003, 11:52 PM   #4
71swb4x4
71swb4x4's Avatar
sorry - forgot to mention that I don't have A/C, so I am pretty sure I don't have that switch down there, it seems to be a problem between the slider lever that we slide back and forth, and the switch that is directly connected to that. No way to adjust it that I could find, but sometimes I can't find the obvioius.
Old 12-15-2003, 12:29 AM   #5
chucks70
The switch doesn't engage until you are 2/3 the way over. The first part is opening the air duct I believe. You can feel when you start into the switch positions.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 12-15-2003, 01:58 AM   #6
71swb4x4
71swb4x4's Avatar
Thanks, that answers that. I appreciate the help.
Old 12-15-2003, 03:52 AM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Check to make sure that the plastic bushing is on the switch also.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
