no tail lights
So earlier this week my tail lights stopped working and then brake lights went also but my rear blinkers are still working. I checked the wires from the cab all the way to the rear end and they are good and cleaned all the connections but still no lights any advice would be amazing right about now.
![]() Join Date: Dec 1999
Re: no tail lights
First I would check the fuses. And then look at the Turn Signal Switch, and or the Head Light Switch. My moneys on the Turn Signal Switch being the culprit.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Re: no tail lights
run a ground wire from the bed to the frame rail
Re: no tail lights
Get a test lite & start traceing. The tail lights are on there own circuit in the light switch. Current goes from the fuse to the switch & then to the tail lights.
