Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-10-2013, 12:08 PM   #351
ColoradoK5
ColoradoK5's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Cool Video! cant wait to see what you do next love what you are doing with the blazer
ColoradoK5 is offline   Reply With Quote
Old 11-11-2013, 12:46 PM   #352
whitels1
whitels1's Avatar
Great job with the Blazer!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-15-2013, 12:14 PM   #353
timmytimm3
Great vid! Mexico is much nicer than I thought.
What a great road to do some testing
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 11-29-2013, 11:33 AM   #354
lyrikz
PITbut
lyrikz's Avatar
Awesome truck man.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 01-14-2014, 02:03 PM   #355
softballnrd27
Always a work in progress
softballnrd27's Avatar
What size are the wheels? 18x?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-14-2014, 11:04 PM   #356
72Blazing
72Blazing's Avatar
What rate coilover springs did you end up going with?
I just received my No Limit wide ride and Fat Bar setup and
Rob sent me 200 and 450s.
72Blazing is offline   Reply With Quote
Old 01-15-2014, 10:49 AM   #357
Wasted Income
Boosted Member
Wasted Income's Avatar
18x9 all the way around.
For the rear, i ended up going with a 375 lb/in spring....but your shock length and location will affect how much spring rate you need.
I also have 450s in the front, but I think it needs more. I have my preload adjuster cranked TIGHT to bring the front end up, so it's not so raked out. But mine started out as a 4x4, so the frame has that extra 1" kick to it that I'm fighting.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-15-2014, 08:34 PM   #358
72Blazing
72Blazing's Avatar
Mine was a 4x4 also. Rob said he would exchange the springs if I needed something
different.
Old 01-27-2014, 11:17 AM   #359
Wasted Income
Boosted Member
Well, an update.
Found out what all the racket in the engine was....
4 bent rods, 5 pistons with broke ring lands, and one piston hitting the crank. lol. Was still running pretty good up until I tore it out of the truck.
Turbo diesel
Old 01-27-2014, 11:27 AM   #360
Hart_Rod
Hart_Rod's Avatar
Heat?
Hart_Rod is offline   Reply With Quote
Old 01-27-2014, 11:47 AM   #361
Wasted Income
Boosted Member
Detonation.
Turbo diesel
Old 01-27-2014, 12:00 PM   #362
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Wasted Income View Post
Detonation.
Ouch!
Old 01-28-2014, 10:03 AM   #363
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
You might want to install a wideband O2 sensor on that new motor. Shes way leanin out.
Tom Vogel is offline   Reply With Quote
Old 01-28-2014, 11:21 AM   #364
Wasted Income
Boosted Member
Lol, ok.
You mean this here wideband?
Trust me when I say, it was most certainly not too lean.
Turbo diesel
Old 01-28-2014, 01:02 PM   #365
lt155ruck
lt155ruck's Avatar
Talking Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Lol. I think perhaps it might be a question of the owner not wanting to loose in some of those exhibitions of speed in "Mexico" ?? Haha you have to enjoy the giggle factor. .. even if it costs an ls motor.
lt155ruck is offline   Reply With Quote
Old 01-28-2014, 11:33 PM   #366
Wasted Income
Boosted Member
This guy. This guy gets it! haha
Turbo diesel
Old 01-28-2014, 11:54 PM   #367
lt155ruck
lt155ruck's Avatar
LOL Next short block please....maybe we should dial the boost back..... NAH more is always better
Old 01-29-2014, 10:36 AM   #368
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
So whats your CR and boost level?
Old 01-29-2014, 11:03 AM   #369
Wasted Income
Boosted Member
Hey, what can I say....I'm greedy
CR before or after the kustom connecting rods mod?
Compression is 9.6:1, boost level was 15-16 psi with some spikes to 18 psi at the shifts....
I mentioned it in another thread, but "boost level" means nothing. 20 psi from a china ebay 60mm turbo is not the same as 20 psi from a PT106.
I'll probably start piecing together a forged shortblock for it, but for now, in goes another junkyard 6.0.
Turbo diesel
Old 01-30-2014, 10:51 AM   #370
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
As you probably know, predetonation has nothing to do with the strength of your bottom end and everything to do with CR, boost level and fuel delivery. Thats a relatively high CR and alot of boost. You need proper Fuel delivery and timing or it will be quick curtains all over again... pronto. An air to air intercooler would make a big difference as well. Or...How about a methanol injection system?
Even if you dont care about grenading the motor, you will get a Huge performance increase if you take care of the predetonation.
Old 01-30-2014, 01:25 PM   #371
Wasted Income
Boosted Member
Tom, I appreciate the advice, however I've already got most of it covered.
Fuel delivery is up to the task. I have a Fuelab 41402 160 gph pump, fed by a -10 sumped tank, which splits to two -8 lines before the fuel rail, and 80 lb/hr injectors. It never...never...went lean. I have lots of logs showing that the fuel system is capable of supplying the correct fuel pressure and AFR even at 16 psi and 7000 rpm.
I don't have room for an A2A intercooler, with my AC stuff in the way. I do already have a dual nozzle meth injection setup on it.
I circled one nozzle, and there is another one on the back side of the pipe that you can't see. I am also running E85.
I plan to upgrade the bottom end, since high cylinder pressure, whether from big hp, or detonation, bends rods. The stock cast pistons also don't give much room for error if you get a little too greedy or get some bad gas or something.
I've built and ran two other big turbo LS motors in the past, and never broke anything with them. Once I hurt this one early on, I didn't really care about it anymore, so I just kept turning up the wick on it to see what it would take before it came unglued...which it never truly did. Call it a science experiment
Turbo diesel
Old 01-30-2014, 05:34 PM   #372
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I am still betting on predetonation. Mighty surprising with E85 Ill admit. Do you have a custom tune on it? If you dont, Id get one. There should be someone close enough to you with a dyno and flash capabilities.. not cheap, but thats what I did with my Mustang and that did the trick for me.
Old 01-30-2014, 05:56 PM   #373
Wasted Income
Boosted Member
I own a commercial version of EFI Live, and have always tuned my own stuff on the street and on the track.
The Blazer however, has a Megasquirt ecu on it, and does not need to be "flashed" in the traditional sense. I can tweak fueling, timing, boost values on the fly and it changes immediately.
Just a friendly heads up, but there is no such thing as "predetonation". I think you're combining two different things.....pre-ignition, and detonation.
http://en.wikipedia.org/wiki/Engine_knocking
Turbo diesel
Old 01-31-2014, 10:26 AM   #374
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
OK then
I stand corected.
http://en.wikipedia.org/wiki/Engine_knocking[/QUOTE]
Old 02-02-2014, 03:47 PM   #375
72Blazing
72Blazing's Avatar
Lots of NMCA and NMRA racers running 12-1 plus compression with high boost levels(30psi+)
With the stock bottom end there could have been any number of contributing factors.
I am sure you will have one hell of a beast when you are done!
