dual tank wont.switch..first step?
The switch on the dual tank is not working on my 85.
Whats are the first few steps to look for besides the fuse? I would really like to fix this problem. THANKS!!! |
Re: dual tank wont.switch..first step?
There are quite a few threads on this subject:
http://67-72chevytrucks.com/vboard/s...d.php?t=512849 There is a diagram here too Forum member Hatzie has wiring schematics for most of these trucks at the below link: 1973-1991 GM Light Truck Service, Unit/Overhaul, & Wiring Manuals in PDFhttp://67-72chevytrucks.com/vboard/s...d.php?t=545416
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper. ![]() Last edited by 8lugnutz; 11-26-2013 at 03:18 PM. Reason: added information |
Which style switch do you have? Early ones were a solid click back and forth, the later ones are a momentary and have a softer rocking motion (also say Depress Fully on bottom of bezel). The early style is prone to failure, momentary are not. I found a good troubleshooting guide once, will look for again.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Thanks 8 lug n 83 GMC I really appreciate it as far as having an early model or newer one, I don't know I have 85 model I will take a picture and post it thanks
Early models had the on/on switch (mine is an '80 and has this type). Later models, including my '86 crew cab, had the "depress fully" type switch. I think yours will have the same type switch as my crew.
I recently went through the same thing you are going through on getting both tanks to work, there are lots of threads on this forum with information. Your truck probably has the 5 pin type valve (I am guessing because of the '85 year model), check out the diagram in the links I posted. As Devin stated above, there is a really good troubleshooting guide in one of these threads, I ran across it when I was researching my troubles, but I couldn't find it either :-(
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper. ![]() |
Great information
#7 | |
Did you find the electrical diagnosis on here yet? When you fully depressed the switch either way does the fuel gauge move?
EDIT, with the key on and every accessory off I can hear my selector valve actuate when I switch my tanks. Can you? Was thinking there might be a blockage/failure with the valve.
#9 | |
I'll try that tomorrow. Thanks |
Born a Chevy Man
Why do you need two tanks anyway? Cost to much just to fill one tank. Unless you are planning on a long trip. I only use the driver side tank and I am one of those guys who likes everything that is suppose to work to work. But I do not care of the right tank works or not. MO
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#11 | |
Amen to that! I don't know about you but up in little ol' WA I need both tanks to get all the way across the state, is kinda nice to be able to do.
Born a Chevy Man
Like I said "Unless you are taking a long trip". But as far as I know, you do not see any more of the double tanks on todays trucks. As far as I know. I also like everything working that is suppose to work. I just very rarely use it. But every now and then when the driver side tank gets low I do fill up the right tank and use it just to keep it in good working order. I think the 80's was the last years for the double tanks. If I am wrong, let me know.
Moderator
![]() Join Date: Oct 2008
Newer trucks like My 2000 GMC have options for larger tanks. Mine has around 30 gallon capacity.
There's absolutely no need to use a Polarity Reversing Momentary MON-OFF-MON switch with any of the square body trucks. The Polarity Reversing ON-ON switch that's listed by the parts stores for 87-91 RV series TBI GM trucks is ![]() All dual tank 81-86 CK and 87-91 RV squares used the exact same Pollack motorized tank selector valve. The valve assembly has internal switching and diodes that park the motor when it reaches the end of its' travel. To answer your question... Usually the switch gets dodgy. They can be disassembled, cleaned up, and lubed... but at $12-$20 for a replacement why bother. Grab a meter and; 1 Check that power is present between Pink and Black wires at the switch plug with the ignition on. 2 Check the switch itself is working properly. If it's the equivalent of the Standard Motor Products DS293 momentary switch that says "depress fully" buy the Delco 7809C and save yourself a headache. My Polarity reversing tank Switching explanation..
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-28-2013 at 01:22 PM. |
#15 | |
Yup I hear ya. Do you know what the fill capacity of the 85 tanks were?... I like the fact that when I pull up to the gas station I have the option to fill either Side depending on what pumps are available lol. |
#16 |
Moderator
Fill capacity could be 16 or 20 gallons on each side depending on how it was optioned.
And please let us know if and how your repairs were successful. |
#17 |
For a longbed if the tanks extend rearward up to the forward rear leafspring hanger they are 20s. If they are 10-12" from it, they are 16s.
#18 |
#19 |
Awesome, I wish I did, but as close as I am to my LS I am thinking rear mount Blazer/'burban now.
How comes your switching diagnosis?
