Old 11-18-2013, 10:52 PM   #1
recboy300
Unhappy 69 c/20 rear axle set up
hello i am new to the site and like all the great info thats hear. that being said can anyone give me a direction togo i have a 69 c/20 and the rear diff is a coil under set up how would i go about putting leaf springs on it and a newer axle.i am only thinking about this because i cant find 3.73 gears or lower for the one i have. i think it has 4.56 now but not good for highway use. any help is greatly welcome thx
recboy300 is offline   Reply With Quote
Old 11-20-2013, 08:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 69 c/20 rear axle set up
I think I would keep the coils and just add axle saddles to the newer rearend.
The ride will be much better.
You might have to add a new track bar,... like a Super Track bar from ECE.
Keith
Convert to disc brakes.
Old 11-20-2013, 10:48 PM   #3
recboy300
oh i didn't know that i could do that awsome thx. where is a good place to look for something like that?
Old 11-21-2013, 08:44 PM   #4
kwmech
If you are good with a torch or know somebody that is, you can use the ones off the axle in the truck. Take measurements first
Old 11-23-2013, 11:11 AM   #5
Mike C
Mike C's Avatar
4.10 is the tallest gear you can get for an Eaton rear. If you can find a coil sprung Dana 60 then you can get 3.54. Not near as common as the Eaton in coil spring however, but they are out there.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-23-2013, 12:47 PM   #6
lolife99
lolife99's Avatar
Early Classic Enterprises= ECE.
www.earlyclassic.com
They have new axle saddles and a Super Track Bar to center your late model rearend.
Keith
Old 11-26-2013, 07:39 AM   #7
recboy300
AWSOME thx for the info. While I'm working on the rear dose anyone know. if I put a drop spindle in the front can I use the coils or do I have to put air bags in ??
Old 11-26-2013, 07:40 AM   #8
recboy300
And are 1/2 ton spindles the same as 3/4 ton spindles ??
Old 11-26-2013, 08:36 AM   #9
lolife99
lolife99's Avatar
Yes you can use coil springs.
No.
They are different.
Different upper and lower balljoints, different outer tie rods and different lower a-arms.
Keith
Old 11-29-2013, 11:37 PM   #10
recboy300
Thx for all the info Keith. I got a hold of ece and they are AWSOME people. You wouldn't know if I have to keep my two piece drive shaft or should I try to switch it over to a one piece when I redo the drive train set up ??
