![]() Join Date: Oct 2011
WTB fuel lines section
looking for the three factory steel lines that run from driver side tank along crossmember between frame rails to selector valve. need metal hold downs and plastic seperators also . hoses can be cut....this is for my 1990 crew cab....pic is from my 1988 crew cab .... thank you very much! pics are sideways...
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Re: WTB fuel lines section
Would a 85 stander cab be the same?
not sure ...is yours a diesel ?...if so i think it may only be a two line set up, but i could be wrong on that....
ttt.....
I have the whole thing if your interested lines clamps and the valve all still together thanks Tim
cool ...sending pm
still need ....havent heard back from timmy71...maybe hes on vaca
![]() Join Date: Jun 2005
i have a set from an 86 c20. $45 shipped for the cross over tubes or add $20 more and it will include everything shown (selector valve works). thanks.
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
cool.. i would like just the steel cross over lines and hold downs/brackets and plastic seperators if that works for you? i have a new selector valve already ...I can send paypal or postal money order or whatever you like ?
i sent you a pm w/ ppal info. thanks!
thanks to 396ci i now have everything to complete my fuel system project..
