Old 12-01-2013, 03:15 AM   #1
swamp rat
swamp rat's Avatar
Conversion?
How difficult is it to convert a C20 to a C10?
Are the frames different?
Can i buy 5 lug disk conversion kits for them?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-01-2013, 08:42 AM   #2
Re: Conversion?
Easy. Just simple parts replacement.
I believe the 20-series frame is heavier (thicker/larger channel)
Yes,you can buy a kit. But,you could also buy the used C/10 stuff or a donor truck. If you aren't looking for drop spindles you can find stock parts for reasonable money from someone who installed drop spindles
Old 12-01-2013, 11:43 AM   #3
swamp rat
swamp rat's Avatar
Re: Conversion?
Thank you, i have only owned my K20 up till now, looking for another..
I'm sure stock spindles with shorter springs would be all I want.
Who would make the kit for the spindles and disk brakes? Need ideas.
Would this just involve swapping the front spindles only? or also the upper and lower A arms?
Guess it would also mean swapping out the rear axles or whole rear end to get 5 lug?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-01-2013, 12:03 PM   #4
67ctener
67ctener's Avatar
Re: Conversion?
I'd just drop a stock 5 lug crossmember out of a truck. Only 10 bolts hold them in. I bet you could do a front rear complete swap for under $500. Unless you have sentimental value in it, you may be better off just buying a c10
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
