Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-02-2013, 01:05 AM   #126
warbucket
warbucket's Avatar
Re: New member with barn find
I bought a repop at Carlisle. I used a brillo pad on my original one and it came out pretty nice. Hopefully I'll be done by spring but it's hard working in the cold, the garage has heat but I have to go outside to paint, weld or grind.
warbucket is offline   Reply With Quote
Old 12-02-2013, 09:52 AM   #127
fast eddie1968
That thing looks great!!!
fast eddie1968 is offline   Reply With Quote
Old 12-02-2013, 10:35 AM   #128
jaros44sr
jaros44sr's Avatar
John, nice work! Just remembered to check for tinted glass....seems like i have both sides,lmk
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-02-2013, 07:12 PM   #129
warbucket
warbucket's Avatar
Thanks Jim, Let me know if ya need a hand when it's start up time, looks like you're getting close.
Old 12-02-2013, 09:37 PM   #130
jaros44sr
jaros44sr's Avatar
One could always use an extra set, thanks for the offer....
SAFETY FIRST
AS usual, off topic
Jim
Old 01-16-2014, 08:40 PM   #131
warbucket
warbucket's Avatar
I've been working on the dash and everything behind it, so far so good, I even got the light, wipers and blower fan working. Now I can start on the fuel tank and lines but I still have to order brake lines.
Old 01-16-2014, 08:48 PM   #132
warbucket
warbucket's Avatar
Some more.
Old 01-17-2014, 10:37 AM   #133
boonedogs72
boonedogs72's Avatar
Looking good!
boonedogs72 is offline   Reply With Quote
Old 01-17-2014, 11:39 AM   #134
richard2717
Equal opportunity joke ofender
richard2717's Avatar
you will be done and driving before you know it....Looking real good
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 01-17-2014, 01:35 PM   #135
jaros44sr
jaros44sr's Avatar
X3 John
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2014, 11:18 PM   #136
warbucket
warbucket's Avatar
With all the snow we are getting here I'm getting a lot done. I was able to get the windshield installed. What a fun job that was, I used two suction cups from Harbor frieght and some rope. The first two atempts I used the glass wheatherstrip from LMC but the chrome trim kept falling out, I couldn't keep it locked in. when that happens you have to start over. I ordered the weatherstrip from http://precisionrestorationparts.com/ and I had it installed in an hour, there weatherstrip would hold the trim in place while you work the seal over the body lip.
Also got the dash 99% done just need a new turn signal cam, I found out the one I have was cracked.
Old 02-16-2014, 01:29 PM   #137
briank
Nice job!
briank is offline   Reply With Quote
Old 02-16-2014, 01:37 PM   #138
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Strong work - looks great!!! Very nice attention to detail. Just a thought - consider adding a stainless cowl screen (from LMC) to keep out the leaves and other debris. I added one (painted black) to each of my trucks as I plan to drive some forested country roads when the snow melts.
Old 03-24-2014, 10:51 PM   #139
warbucket
warbucket's Avatar
I'm happy, I got the engine back today, I had them bump it up to about 315 hp. I have to flip the drivers side valve covers for the oil tupe and move the crossmember forward because of the 700r4 that I installed last week. I also got all the brake lines, fuel lines and the gas tank complete. I just got done making plates for the underside of the roll bar so I can bolt it down, I'll have to fish the front inner plate through the rocker box and pull it through the floor, I welded the bolts to the plate, It should be fun. Oh and the glove box door clears the roll bar about a 1/2" or so. I hope to have it on the road by late spring or early summer. Here's some pics.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
Old 03-24-2014, 10:57 PM   #140
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!! Should be fun!
Old 03-24-2014, 11:17 PM   #141
jaros44sr
jaros44sr's Avatar
Nice attention to detail, well done John. If you are going to use the oem spark plug wire looms, wait till you try to mount up the rear ones by the distri., youll hang by your knees from the ceiling to reach the bolts. I used studs to make it a little more manageable
SAFETY FIRST
AS usual, off topic
Jim
Old 03-24-2014, 11:33 PM   #142
warbucket
warbucket's Avatar
Thanks Jim, That's a good idea. I have a set of headers so I'll guess I'll have to use some aftermarket ones.
Old 03-25-2014, 12:17 AM   #143
jaros44sr
jaros44sr's Avatar
No problem, how does your shop always stay so clean, mine always looks like a hurricane went through......im trying to do better though
SAFETY FIRST
AS usual, off topic
Jim
Old 03-25-2014, 04:52 PM   #144
72gmguy
72gmguy's Avatar
WOW! Haven't checked in for a while. Your project progressed fast and came out awesome! Love the color and great job on all the little details. Looking forward to seeing it done. Will it still fit in the garage with 35s though? That would stink. Is it going to be done for the summer? Good luck!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 03-25-2014, 05:58 PM   #145
mtully79
mtully79's Avatar
Just went through the entire thread, great work on the blazer!
mtully79 is offline   Reply With Quote
Old 03-25-2014, 07:21 PM   #146
warbucket
warbucket's Avatar
LOL, I try to keep it clean for the chevelle but it still gets dust up under the cover and all over the engine.
It will fit with 35's but I think I'm going with 33's, I only have a 2 1/2" lift and with the weight of a winch up front and a 33 on the rack outback should bring it down some. I would like to be driving it down to my sister house in OC NJ early summer, I'll give you a shout when I do and swing by your place.
I had the day off today and could'nt wait to drop the engine in. The poly engine and trans mounts are a PITA to line up, I'll try fighting with them over the weekend. But for now it's in.
Old 03-25-2014, 10:29 PM   #147
mud.man.rj
mud.man.rj's Avatar
Cool, getting closer, take video of it running when you get that far. Nice to see more getting done.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 03-25-2014, 10:47 PM   #148
98Murray
98Murray's Avatar
Looks great!
98Murray is offline   Reply With Quote
Old 03-30-2014, 02:57 PM   #149
madkmart
Awesome work
Looks great
madkmart is offline   Reply With Quote
Old 05-02-2014, 05:21 PM   #150
warbucket
warbucket's Avatar
Video,
