Old 12-02-2013, 02:26 PM   #1
msilva12
'58 Chevy apache 32
I have recently started working on my 58 apache. It has a 350 with a four speed. How can i tell what year model 350 is in the truck? Are all the chevy 350 bolt patterns the same for transmission mount?
This is my first project.
msilva12 is offline   Reply With Quote
Old 12-02-2013, 04:09 PM   #2
arturo7
arturo7's Avatar
Re: '58 Chevy apache 32
Welcome to the board, msilva! How about some pics?
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 12-02-2013, 06:30 PM   #3
OrrieG
OrrieG's Avatar
On the engine in front of the passenger head is a flat pad with the engine number followed by 2 or three letters. Those letters correspond to a specific application by vehicle, carb and transmission. Find an online list and you are set, they are common I have used them on the 350s in my truck and car. On the top of the block behind the driver head is the block casing number and a date code. That will help too and helps identify if it is a 2 or 4 bolt main block.
All small blocks have the same bellhousing bolt pattern up to 91 (I think, someone with knowledge of the newer engines can chime in). Transmission to bellhousing for manual trannies is the same too.
Old 12-02-2013, 11:56 PM   #4
_Ogre
_Ogre's Avatar
one thing nice about working on gm vehicles; all sbc (small block chevy) motors have the same bolt pattern
this includes 265, 283, 302, 305, 307, 327, 350 and 400 small blocks.
and like orrieg stated post up the numbers and someone will put in their secret decoder ring.
oh and
shop air compressor timer
Old 12-03-2013, 12:10 PM   #5
msilva12
my 1958 Apache
Old 12-03-2013, 12:17 PM   #6
msilva12
The guy I got this from said it might need a wiring harness. He thought somebody took it out.
Old 12-03-2013, 04:34 PM   #7
OrrieG
OrrieG's Avatar
You can but the engine harness and front lighting/horn harnesses separatly IF the underdash stuff is still OK. But after 50 plus years the wires and connections get very brittle....
