Old 12-02-2013, 12:09 AM   #1
Irishbleueyes
TH350 or TH400?
Pulling out PG, is either turbo hydro tranny a direct fit?? Is one better than the other?? Thanks in advance..
Irishbleueyes is offline   Reply With Quote
Old 12-02-2013, 01:52 AM   #2
hardcore4life
hardcore4life's Avatar
Re: TH350 or TH400?
TH400 is built to be more heavy duty. It was made to go behind big blocks. If I remember correctly the chevy bell housing should be the same.
68 C10 lwb, 406 sbc, 700R4
86 K30 srw, 454 bbc, TH400
11 Camaro RS, 217 V6, 6M
hardcore4life is offline   Reply With Quote
Old 12-02-2013, 12:31 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Re: TH350 or TH400?
X2...we have a tubo 400 behind Dad's 496 bigblock in his 3/4 ton and we haul heavy loads all the time and bang shift if or burn rubber with it and that tranny is bullet proof. A th 350 is more for a 350 or smaller small block, there are torque and horse power limits as far as I know that you can find so you can tell. My 2 cents. T.J.
Old 12-03-2013, 12:06 AM   #4
Irishbleueyes
Re: TH350 or TH400?
Very cool, so a th350 is perfect for the 283.. Does anyone know if its the same size as the PG?
Old 12-03-2013, 01:37 AM   #5
Captainfab
60-66 Nut
Re: TH350 or TH400?
Yes a TH350 would be perfect behind a 283. As for fitment, it will bolt right up to the engine. As for the length, that depends on which TH350 you have. There are 3 different tailshaft lengths....3, 6 & 9". Either way, moving the trans crossmember and having the driveshaft shortened are easy and inexpensive to do.
Old 12-03-2013, 01:45 AM   #6
Irishbleueyes
Re: TH350 or TH400?
Cap'n Fab, thanks for the info. I haven't bought the th350 yet, so what would you recommend? What torque converter should I use? I figured I would have to do the driveshaft. Thought about adding gear vendors overdrive sometime later.
Old 12-03-2013, 01:55 AM   #7
Captainfab
60-66 Nut
Re: TH350 or TH400?
I prefer the shorter 3" tail shaft housing, but the 6" isn't too bad. All you need is a stock torque converter. Additionally, if you can find a TH350C, which has the lockup torque converter, that will help your mpg's a little. Of course you will have to wire up the lockup feature.
Old 12-03-2013, 02:00 AM   #8
Irishbleueyes
Re: TH350 or TH400?
Perfect, thank you
Old 12-03-2013, 04:49 PM   #9
cg285
Re: TH350 or TH400?
the 400 is obviously beefier but i wouldn't be afraid of the 350 behind a big block
cg285 is offline   Reply With Quote
Old 12-03-2013, 05:02 PM   #10
1963c-10
1963c-10's Avatar
Re: TH350 or TH400?
I'm a manual trans guy myself....but I had a 69 Chevelle SS w/396 BBC and TH400 trans. That trans took a lot of abuse and I never had any issues with it. I'd have no problem running another TH400 in the future. I've never had a TH350, so I can't speak on those.
1964 Short bed trailer
Old 12-03-2013, 09:52 PM   #11
Irishbleueyes
Re: TH350 or TH400?
That th350c with the locking converter sounds great. Is it rare? What yrs were they around??
Old 12-03-2013, 10:03 PM   #12
chevyrestoguy
chevyrestoguy's Avatar
Re: TH350 or TH400?
If you haven't bought a transmission yet, you might even want to consider a 200r4. Plenty strong, and you've got 3 gears plus an overdrive. Enable the lock-up feature, and you've essentially have a 5 speed automatic.
There's nothing wrong with a th350 or a th400, though. Both would be a great choice, but if you've got a 283, I would prefer the th350.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-03-2013, 10:03 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: TH350 or TH400?
Th350s come in 6, 9, and 12 inch tailshaft lengths. There is no 3 inch.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-03-2013, 10:27 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: TH350 or TH400?
I have had many TH350's and they have all been great!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-03-2013, 10:35 PM   #15
Irishbleueyes
Re: TH350 or TH400?
Thought about the 700r4 but all in on that would be about 2200 bucks and I like the idea of the gear vendors overdrive with the versatility of the th350.
Old 12-04-2013, 01:30 AM   #16
Chevy Fleetside
Chevy Fleetside's Avatar
Re: TH350 or TH400?
isn't gear vendors like over $2000. I will be putting the 700r4 behind my 283. I have a one piece aluminum drive shaft to go behind. I also have a 700r4 behind the BB in my other truck. I had a TH350 in my 4x4. I did replace it with a 700R4 and I think I gained about 4 mpg after that. The tranny had mucho miles on it and was still kicking.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-05-2013, 12:14 AM   #17
Irishbleueyes
Re: TH350 or TH400?
A new gear vendor overdrive is about 3 grand but used you can get one for 1000 to 1500. So I can do the th350 now for a lot less then do the overdrive when one comes available and it easier on my pocket.
