need mounting holes/ locations for buddy bucket cab brace
i need to drill the mounting holes for the bud bucket cab brace and want them in the original location, if any body could mneasure the holes from front of bend of the cab to the bend behind the brace and from the door rubbers left and from the right i would be greatly appreciative. thanks rick
Re: need mounting holes/ locations for buddy bucket cab brace
ttt
come on guys i know some one has atruck with this on it originally and can give some measurements!
There is another recent post about this. Advice was to mount the seat with brackets attached in the outside holes and then mark the inside hole location. I'll be doing this soon and have been searching and reading lots of posts about bucket & console mounting. hope others will chime in with advice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
i know how to mount the metal console box i need to mount this
Got it, sorry, I would center it with the glass.
ooooh thats a good idea! thanks! but just incase im still lookin for the measurement
Here are some pictures for you. Center with the tank mounting hole and an inch out from it. From here if you have the bracket use it as a template for the other 2 holes.
#9 | |
Moderator
![]() Join Date: May 2007
Sorry for the hijack Rick, I believe your question has been answered with measurements and pics above, so you should be good to go ![]()
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Thank you so much!!!
i dont have the bracket so i still need the other hole measurements...sorry i will drill the hole in the middle though
The holes for the sides will be 6 1/2 inches center to center from the center hole for both sides.
thanks alot man thats really nice of you! and they are such nice quick aqnd eaqsy measurements to! awesome! thanks alot!!!!!
got the wholes drilled without to much of a fuss! thanks chewy!
#15 |
Hint: Put the bracket on a scanner and scan it for a free paper template.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#16 |
That's a good idea hotrod! Thanks hopefully this thread helps other people to
