Old 12-06-2013, 10:46 AM   #1
463
463's Avatar
Re: Heater Emergency!!!
Originally Posted by Lee H View Post
My heater will not blow hot air after just idling. It takes being driven a few miles and then it heats up slowly. After 3-4 miles it's really hot.
You will have to have a system pressure test to see if there is a leak. in most cases you rad cap is weak. Systems need 15 - 16 lbs psi to work right when it's cold. Start by replacing the rad cap first.
Trueman
463 is offline   Reply With Quote
1972, gmc, heater
