Shift improve kit
I installed a new rear main seal, new oil pan gasket, new bm holeshot 1900 to 2100 converter and tomorrow im servicing the tranny with a filter kit. I know that if i want to install a shift improve kit that it would be the best time cause the tranny is out. Any suggestions on a good shift improve kit? This will be the first time im going to open a tranny but im pretty mechanically inclined. Do kits come with step by step directions and specs? And can it be done in one day? I wont be racing it but i want to know i have the power and get up there. Its a 350 4 bolt main small block with a turbo 350 tranny. Thanks for any help and advice.
1969 chevy C10 longbed |
![]() Join Date: Jul 2013
Re: Shift improve kit
B&M makes the best kits IMHO for the TH350/400. It is easy to do and does come with simple instructions and the needed drill bits to open a few holes in the spacer plate. Truthfully most shift kits for TH350/400 are just a few springs and drill bits. Nothing major unlike 4L60E's those are much more involved, but still easy.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm a Transgo guy. I put one in every transmission I mess with.
![]() Join Date: Mar 2012
are you doing this on a workbench, or installed in the truck? i would be carefull if you are under the truck installing , make sure you dont drop anything or (Springs,Balls ect ect)
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
X2 on the transgo reprogram kit. I also run type F in my th400. Lots of guys have done this. Like a mild shift kit by simply changing oil types. I likely opened a can of worms on this one. Lol. Interested to hear what others have to say.
One of the First
![]() Join Date: Jan 2000
x3
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
My favorite for the TH350 is the Superior HP
However, to get the best results, the middle seal in the direct clutch drum must be removed
