![]() Join Date: Dec 2012
Tilt column swap
I just bought a used tilt for my 72 blazer,got the non-tilt out tonight and it looks the same but different !!does anyone no if there is more to change to make this work? I thought it was a plug and play but i'm thinking i may have the change that inter shaft also ?
Re: Tilt column swap
S/B a direct bolt in....can you show pics of where its differant
not enough hours in the day
It sounds like you may have a van column. It will work with just a little modification. Here is a thread on it, http://67-72chevytrucks.com/vboard/s...d.php?t=147927. I put one in my Blazer and it was not hard to do.
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
I do think now it may be out of a van!will confirm over the week-end,thanks for all the info!
