Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-19-2013, 11:26 PM   #226
Captainfab
60-66 Nut
Re: Camaro Caliper Brackets
Reply sent
Originally Posted by Dads79GMC View Post
Captainfab, I'll take a set. I will send you a PM is a minute. Thanks Mike
Captainfab is online now   Reply With Quote
Old 11-26-2013, 11:07 PM   #227
BLUE THUNDER
BLUE THUNDER's Avatar
anymore kits available???
BLUE THUNDER is offline   Reply With Quote
Old 11-27-2013, 12:17 AM   #228
Captainfab
60-66 Nut
Yes I always have these available, no limited runs here.
Would you like them in bare steel or satin black powder coat?
Old 11-27-2013, 03:49 PM   #229
ryserstine
ryserstine's Avatar
Hello captainfab I would like a pair of your Camaro caliper rear brake brackets (non painted) my name is mark ryser paypal payment on its way thanks
ryserstine is offline   Reply With Quote
Old 11-28-2013, 12:34 AM   #230
Captainfab
60-66 Nut
Hello Mark
I did receive your payment, and your brackets shipped out today. With tomorrow being Thanksgiving, I'm not sure if you will receive them Saturday or Monday. Thanks for the purchase
Old 12-07-2013, 01:34 AM   #231
dan468
dan468's Avatar
Why is a new master cylinder needed? I understand the proportioning valve.
Thanks!
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 12-07-2013, 01:47 AM   #232
dan468
dan468's Avatar
Originally Posted by 425HP409 View Post
I installed the kit from Captainfab, and it works great. I resolved two issues with the installation, Combination Valve and Parking Brake Cables
1. Combination valve - I used the factory 68 brake light switch, no proportioning valve and no metering valve. No metering valve needed with 4 wheel disc, and so far works great with no proportioning valve. I installed a master cylinder for 4 wheel disc so as not to have a residual check valve in the outlet of the master cylinder, which is only used on drum brakes. My truck started out as a 4 wheel drum and I had previously installed 72 disc brakes.
2. Parking Brake - My truck is a short bed, however the long and short bed trucks use the same rear cables, so my method should work for all trucks. I was able to use the Camaro factory rear parking brake cables and the factory Chevy intermediate cable. I moved the intermediate cable from the trailing arms to the inside of the frame, connecting to the Camaro cables. I fabricated new brackets for the front of the rear cables and made links to take the slack out of the intermediate cable. The photos show how I did it.
Thank you!! This will save me some headache. I have a 4-link and didn't have any means of hooking up to the old trailing arm mount.
68 C-10
Build thread
Old 12-07-2013, 06:06 PM   #233
ryserstine
ryserstine's Avatar
Size:  45.8 KBThanks captainfab for the brackets it made my drum to disk brake fab a breeze! Here are some installed pics thanks again.
Old 12-08-2013, 12:57 AM   #234
Captainfab
60-66 Nut
You don't mess around......looks good Mark.
I see you converted your square to trailing arms
Are those NASCAR arms?
Attachment 1184333Thanks captainfab for the brackets it made my drum to disk brake fab a breeze! Here are some installed pics thanks again.
Old 12-08-2013, 12:59 AM   #235
JustN
these use the 00 camaro/firebird calipers right?
JustN is offline   Reply With Quote
Old 12-08-2013, 02:25 AM   #236
Captainfab
60-66 Nut
No they do not
'93-'97 F-body calipers as listed in the first post.......
Old 12-09-2013, 04:32 PM   #237
ryserstine
ryserstine's Avatar
Yes I converted my sq. to trailing arm (nascar). Can you look at these pics. of my x member. All is square, lined up, and pinion is good but I want to be sure before I weld up my spring perches. How much clearance must I have for my driveline through my x member opening. First pic is of the x member half done I could take another shot of it completed but I need to weld up those perches first so nothing moves" AAAGGAAIIIINNN" THIS DID ALMOST KICK MY ASS!! The other is the driveline, your help would be much appreciated.
Old 12-09-2013, 04:34 PM   #238
ryserstine
ryserstine's Avatar
I hope I didn't create any problems asking you this question here
Old 12-09-2013, 11:43 PM   #239
Captainfab
60-66 Nut
Not a problem.
For clearance, I would like to see at least 1/2" between the driveshaft and the crossmember at the extremes of the suspension. By that I mean 1/2" at the top at full compression and 1/2" at the bottom at full extension. Your side clearance looks good from what I can see.
Old 12-11-2013, 01:42 PM   #240
ryserstine
ryserstine's Avatar
Great I'm good then! Off to find some posts on setting up my pan hard bar,i love this site! Thanks again for the super parts and the info.
Old 12-11-2013, 02:29 PM   #241
63jalopy
Hi, I just sent paypal payment for the camaro calipers,not powder coated.
Thanks, Josh
63jalopy is offline   Reply With Quote
Old 12-11-2013, 02:30 PM   #242
dan468
dan468's Avatar
Thanks!
anyone?
68 C-10
Build thread
Old 12-12-2013, 12:39 AM   #243
Captainfab
60-66 Nut
I received your payment and your Camaro caliper brackets shipped out today. You should receive them either Saturday or Monday.
Thanks, Josh
Old 12-12-2013, 12:44 AM   #244
Captainfab
60-66 Nut
Assuming you currently have a dual reservior drum/drum master, that master cylinder does not have enough volume for calipers, plus they have built in residual valves. Now if you have a disc/drum master, the same would apply, but only to the rear circuit. Althopugh, I have seen masters on some of the C20 squarebodies that look just like a disc/disc master cylinder. I just do not know for sure if they are the same internally.
anyone?
Old 12-12-2013, 12:45 AM   #245
dan468
dan468's Avatar
Excellent thank you, I will send money soon
68 C-10
Build thread
Old 12-13-2013, 02:51 PM   #246
ryserstine
ryserstine's Avatar
So captainfab whats a good year pickup to grab a disk/disk mastercylinder off of? Or does someone make one for my square body. Thanks
Old 12-14-2013, 12:29 AM   #247
Captainfab
60-66 Nut
I beleive most guys are using the '77-'81 Corvette master cylinder
Old 12-14-2013, 08:58 PM   #248
ryserstine
ryserstine's Avatar
Ok so 77-81 vette and it fits nothing else i'll need. I no i'll probably have to do some reflaring of brake lines, and an adjustable proportioning valve for the rear but my concern is the plunger size,and my existing proportioning valve. Leave it or get rid of it? Thanks mark
Old 12-15-2013, 12:27 AM   #249
Captainfab
60-66 Nut
Yes the Corvette master cylinder will bolt right up. Just like most GM parts, there are a lot of master cylinders that are interchangeable.
You can try using your original proportioning valve with an adjustable valve in the rear circuit and see if that works for you. The other options would be to change to a disc/disc prop valve or the Wilwood #260-11179 prop valve which has a built in adjustable valve for the rear.
What do you mean by 'plunger'?
Old 12-15-2013, 12:38 AM   #250
dan468
dan468's Avatar
CPP has a bunch of valve options too that will work with the original brake warning switch
68 C-10
Build thread
