Old 12-09-2013, 11:32 AM   #1
Mgicm
Remove s10 wheel and column
Hi
Have a 51 AD s10 swap and wanted to redo what was done and remove the cab. How do I remove the wheel and column? I have the nut & three screws off the wheel but not sure how to get the wheel off. Assuming a steering wheel puller?
If I wanted to pull out whole column, how do i remove it as it is a s10 column with turn signals and tilt.
Sure appreciate it.
thanks Kev
Mgicm is offline   Reply With Quote
Old 12-09-2013, 03:43 PM   #2
N.T.Q
Re: Remove s10 wheel and column
hammer the back side of it with a dead blow hammer it will pop off
N.T.Q is offline   Reply With Quote
Old 12-09-2013, 04:02 PM   #3
Fatbear
Yes you can use a steering wheel puller for the wheel. the whole column, take the coupler loose under hood,bolts holding column to dash unplug your wires ,unless they are wired in then mark them first and cut them.If you are using column shifter will also have to disconnect it too.
Fatbear
1952 yellow 3100
350 v8 on sonama frame
Fatbear is offline   Reply With Quote
Old 12-09-2013, 04:08 PM   #4
Mgicm
would rathe rnot have to buy a puller so was looking for another way. Im also deciding whether I should just pull whole column as I hate the plastic s10 one. But that gets into an area im not familiar with..columns, ujoints, etc.
thanks
Old 12-09-2013, 04:28 PM   #5
mr48chev
mr48chev's Avatar
That is absolutely the wrong way to remove any steering wheel. Especially one on a collapsible column. It will break the plastic pins in the steering shaft before the wheel comes off.
The correct way is to use a steering wheel puller as a couple of guys mentioned. If you have an Autozone or O"reilly store close by you can most likely "borrow" one by paying for their loaner and then returning it for a refund when you are done with it.
http://www.autozone.com/autozone/acc...uller/_/N-2652
My ongoing truck projects:
Old 12-09-2013, 10:55 PM   #6
Russell Ashley
Russell Ashley's Avatar
I am assuming that you think a steering wheel puller would be more expensive than they are. Here's an example from EBay.
http://www.ebay.com/itm/Steering-Whe...2a83a0&vxp=mtr
Either borrow, rent, or buy one but whatever you do, don't hammer on the column or wheel.
Russell Ashley is offline   Reply With Quote
Old 12-10-2013, 12:22 PM   #7
mr48chev
mr48chev's Avatar
I think average retail on one of those pullers is right at 20 bucks Amazon.com: Lisle 45000 Steering Wheel Puller:... Amazon.com: Lisle 45000 Steering Wheel Puller:...
A guy could make his own if he had to.
Old 12-10-2013, 08:12 PM   #8
hard3
HF has a kit that does steering wheel and lock plate for $35 . lock plate tool is to compress lockplate spring to remove snapring. Needed if replacing key cylinder when missing key.
hard3 is offline   Reply With Quote
