Remove s10 wheel and column
Hi
Have a 51 AD s10 swap and wanted to redo what was done and remove the cab. How do I remove the wheel and column? I have the nut & three screws off the wheel but not sure how to get the wheel off. Assuming a steering wheel puller? If I wanted to pull out whole column, how do i remove it as it is a s10 column with turn signals and tilt. Sure appreciate it. thanks Kev |
Re: Remove s10 wheel and column
hammer the back side of it with a dead blow hammer it will pop off
Yes you can use a steering wheel puller for the wheel. the whole column, take the coupler loose under hood,bolts holding column to dash unplug your wires ,unless they are wired in then mark them first and cut them.If you are using column shifter will also have to disconnect it too.
Fatbear 1952 yellow 3100 350 v8 on sonama frame |
would rathe rnot have to buy a puller so was looking for another way. Im also deciding whether I should just pull whole column as I hate the plastic s10 one. But that gets into an area im not familiar with..columns, ujoints, etc.
thanks |
#5 | |
![]() Join Date: Jul 2007
The correct way is to use a steering wheel puller as a couple of guys mentioned. If you have an Autozone or O"reilly store close by you can most likely "borrow" one by paying for their loaner and then returning it for a refund when you are done with it. http://www.autozone.com/autozone/acc...uller/_/N-2652
I am assuming that you think a steering wheel puller would be more expensive than they are. Here's an example from EBay.
http://www.ebay.com/itm/Steering-Whe...2a83a0&vxp=mtr Either borrow, rent, or buy one but whatever you do, don't hammer on the column or wheel. |
I think average retail on one of those pullers is right at 20 bucks
![]() A guy could make his own if he had to.
HF has a kit that does steering wheel and lock plate for $35 . lock plate tool is to compress lockplate spring to remove snapring. Needed if replacing key cylinder when missing key.
