12-08-2013, 06:20 PM | #1 |
1974 Brake Line Routing
I did a search and got some good pictures of the lines coming out of the proportioning valve but I could use a picture of how the two lines are routed and clamped down from the master cylinder to the proportioning valve near the power steering lines.
Mine seems like it is under a lot of pressure. Lynn |
12-09-2013, 09:25 AM | #2 |
The One And Only !!!
Re: 1974 Brake Line Routing
My 74......
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-10-2013, 12:23 AM | #3 |
Thank You for the pictures.I have my lines going over the top of the power steering lines and need to correct them.
Lynn |
