Old 12-09-2013, 07:29 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
What "stock looking" air cleaner will fit edelbrock 1406
I bought a new crate engine that will be all black. My rusty chrome circular edelbrock one will look out of place.
I'd like to replace it with one that will fit over an edelbrock 1406 (I'm fine with using a spacer).
If I go junkyarding or ebaying what ones will appear stock-ish and function properly? I'll even buy new if not too $$$.
Pics are always good too
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-09-2013, 07:45 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: What "stock looking" air cleaner will fit edelbrock 1406
Most factory 4 barrel air cleaners will fit. Bring a tape measure or ruler and check the opening to be 5 1/8", as that's what an Edelbrock (and most 4 barrels) takes.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 12-09-2013, 07:54 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I have a stock air cleaner and spacer on my Edelbrock.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-09-2013, 07:55 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Me too, on my '69 Suburban with a Black crate engine....
LockDoc
Leon
Old 12-09-2013, 08:15 PM   #5
67ChevyRedneck
I'm definitely going to have to find one at a pick n pull... people want $80-100+ for a used one? I think I have a Pontiac one I had been saving for my firebird somewhere in the shed... that may fit, never tried it. Never knew they were worth so much, my dad has probably tossed/scrapped over a hundred of the dang things.
Jesse James
Project "On a Dime"
Old 12-09-2013, 08:15 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
You may need a banjo fitting to fit some stock air cleaners without a spacer, but most stock air cleaners will fit. If you are junkyard diving, don't forget to check out Olds, Buicks, and Ponchos - a lot of them had 4 barrels.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-09-2013, 08:29 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Any GM 4 barrel air cleaner will fit, as stated above. They are a dime a dozen at most pick n pulls due to the many models that used them. No need to pay more than about $20 for one and clean it up and paint it yourself. The stock spacer is present on just about every truck I run across and also found on the parts board.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-09-2013, 08:32 PM   #8
67ChevyRedneck
So there is a spacer I should use? Is it metal or plastic?
I didn't think a used one should be more than $20-30. There has to be a billion of them around.
Jesse James
Project "On a Dime"
Old 12-09-2013, 10:30 PM   #9
1972SUPERSB
1972SUPERSB's Avatar
Here is my setup. Edelbrock 1406 with stock air cleaner. I used stock spacer as well
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-09-2013, 10:31 PM   #10
1972SUPERSB
Another view
Jeff
Old 12-10-2013, 12:34 AM   #11
MattPSU
MattPSU's Avatar
Jessie - I have my original stock one that I'm not using. It's in good shape and just hanging on the wall. Could use to be repainted but overall it's not bad. If you're interested, maybe we could trade - you could weld a few things on my truck and/or give me a welding lesson for it. - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 12-10-2013, 12:40 AM   #12
67ChevyRedneck
You can weld as well as I can!
Dang it! I just made an offer on a complete set (hose, riser, air cleaner) on the parts forum.
If that falls through I'll take it. If not, I can still hopefully show you a thing or two. I'm not great at it, but I can fill holes
My cheap crate engine is starting to cost me a lot of $!
Jesse James
Project "On a Dime"
Old 12-10-2013, 12:45 AM   #13
MattPSU
MattPSU's Avatar
Maybe - but you also own a welder! That makes you more of a welder than me.
Let me know - I have the riser and hose somewhere, too.
Old 12-10-2013, 02:59 AM   #14
67chevy1series
67chevy1series's Avatar
I'm using the stock 67 air cleaner with a 80's/90's spacer those are like about an inch and 1/4 tall compared to the original ones which are close to 3"
67chevy1series is offline   Reply With Quote
Old 12-10-2013, 09:00 AM   #15
jocko
jocko's Avatar
LockDoc
me three. I think the key here may be "with a spacer." Not sure it will fit the edelbrock without the/a spacer. The 80-90's spacer is a GREAT idea, the stock one is a bit tall...
Old 12-10-2013, 10:55 AM   #16
cdowns
cdowns's Avatar
you can blast the rusty chrome one and paint it flat black and use that one
Old 12-10-2013, 11:07 AM   #17
Ft.ValloniaStreaker
Ft.ValloniaStreaker's Avatar
cdowns my break is @ 10:00 .....couldn't answer fast enough,that's what I'd do.
Ft.ValloniaStreaker is offline   Reply With Quote
Old 12-10-2013, 11:45 AM   #18
67ChevyRedneck
I want something that's more stock looking. I'm going to take Matt up on his freebie offer, he only lives minutes from me
Jesse James
Project "On a Dime"
Old 12-10-2013, 04:58 PM   #19
MattPSU
MattPSU's Avatar
When did I say free??? I said trade or work something out!
Old 12-10-2013, 05:21 PM   #20
67ChevyRedneck
In my mind, that's free! My friends never pay me for my time and they always disappear when I need something, so in my mind, it's free. I spent 3 days putting new plywood, carpet, and built a new console on a pontoon boat, then put all the rails back on for some pizza.
Jesse James
Project "On a Dime"
Old 12-12-2013, 10:09 AM   #21
Stock air cleaners just look right,but open elements yield much better HP. I'm sure mileage,too. I've painted these black for a great compromise of factory-ish appearance with best performance. I run an Eldelbrock open element w/spacer on my '72 w/Edelbrock carb/intake. It's not trying to be 100% original,just close,and that's what we all did from day one. I have a Z28 dual snorkel for my '67 project because I want that era performance look (got the valve covers,too). But,I'll have an open element to slap on for when I want it to run best. Even when I run a stock air filter I usually flip the lid to get that air in there. They are just so restrictive.
