Old 12-08-2013, 04:32 AM   #1
Cobra427sc
Tires and Rim sizes are you Guy's running with the Camaro Clip on 55 56 57 Chevy P/U
Hey Guy's tiring to figure out what sizes of tires I can use that will fit my 56 Chevy P/U Truck, with the 1980's Camaro front clip change.
The rear end is a 10 bolt from a 80's Camaro at 62.50"in width.
Also it would help if I knew your rear suspension setup, as I'm using a 4 link Triangulated with Coil Over Shocks.
I would like to know if your setup is tubed or not.
Thanks for the Help Guy's.
Reg.
Cobra427sc.
Cobra427sc is offline   Reply With Quote
Old 12-08-2013, 01:38 PM   #2
1adam12
1adam12's Avatar
Re: Tires and Rim sizes are you Guy's running with the Camaro Clip on 55 56 57 Chevy
Cobra
I'm running 18x8 with 4.5 backspace. 245/45/18 tires. No tub 10 bolt axle with it flipped and c notched.
Hope this helps.
1adam12 is offline   Reply With Quote
Old 12-08-2013, 02:53 PM   #3
Cobra427sc
Originally Posted by 1adam12 View Post
Cobra
Hope this helps.
Hey 1adam12!
Got a picture of her???
Is that 18x8 at 4.5 BS all the way around?
Also the 10 bolt is it a Camaro rear end?
Thanks Buddy.
Cobra427sc.
Old 12-09-2013, 09:30 AM   #4
1adam12
1adam12's Avatar
All 18x8 4.5 backspace..yes its a camaro rear end 10 bolt here is a pic hope these help i can send more
Old 12-09-2013, 09:36 AM   #5
1adam12
1adam12's Avatar
Here are a couple more
Old 12-09-2013, 11:03 AM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Very nice truck! I'm in a neverending argument with myself over ifs or a dropped axle, Posie's Super Sliders, rebuilt kingpins, etc. yeah, I know I'd have nearly as much $$ tied up if I go that way and it won't ride as well but I kinda like the idea of improved originality. Kinda like the street rid guys do with 30's Fords.
Anyway, is your truck a static drop or bagged? Any rubbing issues on turns, entering driveways! Personally, I'm waay over the entering diagonally phase of my life. I want it lower without that BS.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-09-2013, 11:27 AM   #7
1adam12
1adam12's Avatar
Dan
Static drop left side will rub a bit in tight turns I have to trim the fender a bit..She rides ok...I don't scrap at all..when i first got here the rear end was hitting the frame so I notched it..so far so good...I have a front clip problem i think the PO installed it wrong so this winter i will be addressing that issue.its getting there Slowly....
Old 12-09-2013, 09:21 PM   #8
Cobra427sc
Hey 1adam12!! Sweet!!
Old 12-09-2013, 09:24 PM   #9
Cobra427sc
Reg.
Cobra427sc.
Someone is offering me a good price for Mags. I just don't know if the will fit these trucks. This is what the dimensions of the Mags he's got, I would prefer not to have to tub my box.
What would be the out come if I bought these??
Front wheel are 15x8 (BS) 4 1/2 The rear wheel are 15x10 (BS) 4”
All info would help!!
Thanks.
Cobra427sc.
Old 12-09-2013, 09:26 PM   #10
Cobra427sc
That's just Sweet 1adam12!!
Old 12-10-2013, 01:18 AM   #11
1adam12
1adam12's Avatar
Cobra
With my 18x8 I have bout an inv h give or take on each side of rear fender. Hope this helps.
Thanks for the props on my truck. Let me see if I can find some pics of the rear.
