Old 12-10-2013, 01:42 PM   #1
Jahloha
Jahloha's Avatar
What Bare Metal Frame Primer (brushable)
Team:
Last night I worked on a small section of my frame and quickly brought the frame to bare metal. I originally had planned on ZR or Por 15 for my frame paint because did not expect the wire wheel to clean up the frame so quickly and nicely; so now, I am wondering how I would go about choosing a primer for the bare metal.
I do not have a sprayer or space to spray, so I plan on using a brush/spray can to apply the primer and paint (brush or spray as well) afterwards. For those of you who have taken the frame to bare metal than primed it, what primer did you use? How did it work out?
Here is the area of the frame I worked on and got these results:
Name:  After Wire Brush.jpg
Name:  More Wire Brush Cleaning.jpg
Mahalo!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-10-2013, 02:20 PM   #2
Drewski23
Re: What Bare Metal Frame Primer (brushable)
i think if you use por-15 you dont need primer..but i think you should scuff the surface first..i think
Drewski23 is offline   Reply With Quote
