Old 12-10-2013, 04:52 PM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Toying with the idea of C30 to K30 conversion
Gents,
I'm toying with the idea of doing a 4x4 conversion on my '72 GMC. It gets used for hauling firewood out back and other things for which it would be useful.
So, that said, looking for input or info from anybody who's done this before. I've done some searching and I've come up with not a whole lot.
I also have a slight dilemma in that this truck has a PTO driven hydraulic bed setup and I'd like to not have to completely rework everything to move it to clear the transfer case.
With all this in mind, I've come up with this:
-78+ SM465 (32 spline output 4wd with NP208 transfer case adapter)
-BW4401 or BW4470 1 ton transfer case from a 87-00 K3500
-D60 driver's side pumpkin - this would come from a Ford 1 ton and swap the knuckles/brakes to Chevy parts
As far as the front springs go, I'd probably use 3/4T rear springs, and make custom hangars so I don't have to drill through the frame. This would also give me a bit of a front end lift.
I'd probably then add some blocks in the rear, or possibly flip the hangars and add longer shackles, to keep it level.
Obviously I need custom drive shafts for this. The rear I should just be able to shorten the mid-shaft.
I don't see any particular reason to swap my engine cross member, as all the front end components are bolted to it and can be removed. If I need to, I'd probably use one from a K20.
I understand it'll be a bit of work, but this seems doable to me. Am I crazy or not? Comments / advice appreciated!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
