Old 12-11-2013, 02:28 PM   #1
67c10redneck
67 power steering with a 5.3 vortec motor?
Hey guys my question if can I use my stoc power steering pump on my 5.3 vortec engine that I put in with a stoc 67-72 power steering gear box? What lines will I need and anything has to be adapted. I know the frame will need fab work. Thanks
67c10redneck is offline   Reply With Quote
Old 12-11-2013, 03:12 PM   #2
joesgreen67
joesgreen67's Avatar
Re: 67 power steering with a 5.3 vortec motor?
Just swap the fittings on the back of your 67-72 pump and 5.3 pump.
They thread into the pump body with the same thread. No need to change hoses.
joesgreen67 is offline   Reply With Quote
Old 12-11-2013, 03:49 PM   #3
VroomVroom68
Yes, just buy the 5.3 water pump fittings, should be available at your GM dealer.
VroomVroom68 is offline   Reply With Quote
Old 12-11-2013, 04:11 PM   #4
67c10redneck
I do not have the stock pump or any hoses so I will need to buy them but I can go to any auto parts store and get the hoses for a 67 and they should fit on the 99 pump?
Old 12-11-2013, 09:53 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
You need the sae fitting to replace the metric fitting in the back of the ls ps box then you can use the stock 68-72 hoses. 67 had a quite different power steering setup.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
