Old 12-12-2013, 12:28 PM   #1
airbrushguy
'71 C10 fresh air vent?????
In the process of replacing rust in my truck, I've noticed all the crap that has accumulated in my "vent box" at the outside of the cowl. The former owner had installed a ss screen under the cowl yet it has rotted. How can this be prevented?
airbrushguy is offline   Reply With Quote
Old 12-12-2013, 12:30 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: '71 C10 fresh air vent?????
I used regular screen porch screen. It's been under the cowl for several years now and still works good.
Keeping it inside the garage works the best though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-12-2013, 12:34 PM   #3
airbrushguy
This truck will not sit inside. Is there supposed to be a drain that I don't see?
Old 12-12-2013, 12:36 PM   #4
Molberg
Molberg's Avatar
LMC sells cowl screen kits for under cowl. I tacked expanded metal to outside lower holes on cowl panel as well.(behind front fenders.. under cowl) Cant see them without lookin up under cowl... Keep critters out too
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 12-12-2013, 12:39 PM   #5
Molberg
Molberg's Avatar
under inside corner of cowl panel... near front pillar. Drain hole that plugs
-Project Nitemare-
Old 12-12-2013, 12:54 PM   #6
airbrushguy
Here's my problem. Not near truck now, can you get to that drainplug when fender/door etc are on?
Old 12-12-2013, 12:54 PM   #7
Molberg
Molberg's Avatar
Lay on your back and look straight up above front of outer rocker... Lol. You'll see a gap between the cowl panels
-Project Nitemare-
Old 12-12-2013, 12:56 PM   #8
Molberg
Molberg's Avatar
It'd be tough... Mice like to nest in that area of your pic. Look under the area of our pic... You'll see the drain I covered in expanded metal.
-Project Nitemare-
