12-11-2013, 11:15 PM | #26 | |
Re: Tow/Haul mode
EDIT: After rereading above, I think switch one activates the sport mode (changes the transmission tune) but transmission will still shift it self. Switch 2, activates the paddle shifters such that you can manually shift the transmission. Just my interpretations of how it works, LOL.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-12-2013, 01:10 AM | #27 | |
meowMEOWmeowMEOW
Re: Tow/Haul mode
Is the GM tap-shift system one that allows for the paddle shifters to override the set shift patterns (i.e., if you don't shift, it will before you damage the engine), OR the kind that allows the simulated "full manual" situation, like how a reverse pattern FM valve body might? (i.e., 1st is first until you shift...even if it means over-revving or essentially being stupid).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
12-12-2013, 09:52 AM | #28 | |
Re: Tow/Haul mode
12-12-2013, 11:19 AM | #29 |
Boosted Member
Re: Tow/Haul mode
I've never enabled the manual mode on any of my stock PCM swaps, so I can't speak to that functionality. However, I'd imagine it's similar to my Megashift, in which it simply enables tap-shift mode....which by the way I think is an over-rated gimmick.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-12-2013, 12:19 PM | #30 |
Re: Tow/Haul mode
I agree. About the only good use of the Tap-shift mode is the ability to keep the tranny from kicking into OD when you are cruising at the crossover speed...at least in the A6's, since you cannot manually select all gear positions.
12-12-2013, 01:15 PM | #31 |
Re: Tow/Haul mode
I don't plan on using it a ton either, but I'd rather have it set up before I get a tune done instead of having to go back later. Thinking about using one of these so i know when the performance mode is on. Pretty sure it will work...
Amazon.com : Silver Metal Stainless Steel Red LED... The ability for manual shifting is neat, but i can't I've ever felt the need for paddle shifters or the like. I prefer full auto or a stick. My mothers Audi has the bump shifter ability and the only time i use it is when it takes off from a stop. For some reason it wants to immediately shift into second before it even moves...
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
12-12-2013, 05:47 PM | #32 |
Boosted Member
Re: Tow/Haul mode
I use the tow/haul/performance mode quite a bit. I usually set it up as "drag" mode. Higher shift points, firmer/faster shifts, and NO torque management.
Billett, I don't believe that will work for you unless you use a BCM. There is no feedback from the PCM that it's in performance mode. The BCM is what powers the light on the dash in trucks that have it. The button itself will work, but it won't light up when in perf mode and turn off when not.
12-12-2013, 06:10 PM | #33 |
Re: Tow/Haul mode
I use mine as a DD and hope to get better mileage out of it. This would be more for the occasional pull against my brothers' vehicles.
As far as the switch goes, i know they make momentary switches that use the 12v side to light the ring by moving a mechanical switch on the inside every tinge the button is pressed. Honestly though, i just wanted to know when it was on or off and i feel like the changes will be drastic enough that I'll KNOW when its on. otherwise what's the point right? Haha
